Has anyone ever done this before?
Old Jan 7, 2006 | 05:54 PM
Boostage's Avatar
Default Has anyone ever done this before?
Copper oil feed and vacuum lines?
Old Jan 7, 2006 | 06:10 PM
siblues's Avatar
Default Re: Has anyone ever done this before? (Boostage)
Thats pretty sick.I wonder if that works as good as I think it does thats definitely different. I like
Old Jan 7, 2006 | 06:30 PM
11psiTurboSI's Avatar
Default Re: Has anyone ever done this before? (siblues)
I wonder if there is any vaccum leaks?
Old Jan 7, 2006 | 06:43 PM
stinker504's Avatar
Looks like SS line.
Old Jan 7, 2006 | 07:08 PM
sikciv666's Avatar
Default Re: (stinker504)
thats a sick set up.
Old Jan 7, 2006 | 07:29 PM
Adi Radoncic's Avatar
On Fire!
I might be wrong but I think there is too much vibration under the hood of a car to run copper lines and to have them last a long time. I think they would eventually brake off at the fittings.
The lines look clean but HOLY fittings batman!!
Old Jan 8, 2006 | 06:07 AM
bigdaddyvtec's Avatar
* B A N N E D *
Default Re: Has anyone ever done this before? (Adi Radoncic)
YUK... Sorry just my OPINION.... looks like a pain in the *** to work on, around.... but nicely done....
Old Jan 8, 2006 | 07:09 AM
silentdaredevil2's Avatar
i think those are stainless steel hardlines copper has a more golder look to it
Old Jan 8, 2006 | 07:19 AM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adi Radoncic &raquo;</TD></TR><TR><TD CLASS="quote">I might be wrong but I think there is too much vibration under the hood of a car to run copper lines and to have them last a long time. I think they would eventually brake off at the fittings.
Subarus use em. . . .
Old Jan 8, 2006 | 07:21 AM
Forrest Gump 9's Avatar
Default Re: (silentdaredevil2)
You better off with SS braided line. You have to be extremely careful to work around them. Niceturbo set-up though.
Old Jan 8, 2006 | 07:52 AM
Turbocivic94's Avatar
Default Re: (Turbo9Nut)
Sick setup
I wouldnt do it
Old Jan 8, 2006 | 08:17 AM
nickromeo's Avatar
WTF IS GOIN ON THERE!
Old Jan 8, 2006 | 08:18 AM
boosted94cx's Avatar
* B A N N E D *
it looks really good...but, it just needs to be more hidden...looks weird just sitting right there in the open....
Old Jan 8, 2006 | 08:37 AM
91civicDXdude's Avatar
i did a turbo install on a friends car (b16 EG with greddy 18G) and used copper line for his oil feed for the turbo. worked great.
Old Jan 8, 2006 | 08:39 AM
Finland's Avatar
I bet that car is owned by a pipefitter, there's no reason to do that otherwise.
Can you imagine trying to work around all that piping? Even if I were dumb enough to run hard piping for vacuum lines, I'd certainly use stainless, not copper.
I say it's a total waste of time and money, let alone having a hundred potential leak points.
Old Jan 8, 2006 | 08:42 AM
mxpx035's Avatar
Default Re: (Mr. Helsinki)
it looks like stainless steel to me and they use that **** on hydraulic car setups it is pretty durable and olds up to vibrations copper would be to weak
Old Jan 8, 2006 | 08:45 AM
Boostage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Helsinki &raquo;</TD></TR><TR><TD CLASS="quote">I bet that car is owned by a pipefitter, there's no reason to do that otherwise.
I say it's a total waste of time and money, let alone having a hundred potential leak points.</TD></TR></TABLE>
Dude think before your talk, This is what a b series intake looks like..
and this is what an Ls1 intake looks like.
Not too easy to tap a bumch of holes in a composite intake. stress cracks..
Old Jan 8, 2006 | 08:48 AM
* B A N N E D *
he never said anything about tapping anything?
Old Jan 8, 2006 | 10:25 AM
ringgold's Avatar
Default Re: (s13-t)
I have seen several Harley Davidson's and Triumph motorcycles with copper oil lines and I think fuel lines cant remember right off. If anything vibrates those bikes do and they seem to hold up fine.
Old Jan 8, 2006 | 01:05 PM
i agree working around that stuff would suck because that tubing bends so easily
Old Jan 8, 2006 | 01:15 PM
rainmanEK's Avatar
big strong guy
My Father Has Soild Copper Oil lines for his turbo...
Eric
Old Jan 8, 2006 | 02:49 PM
mrbsponge's Avatar
i agree with the copper lines for oil, although a piece of rubber here and there in a few sections wouldnt hurt either, kinda like old 300zx-TTs.
but seriously that ls1 is overkill with the lines, i cant imagine the time it took to flare all those lines and get it together.
oil yes
vacuum no
Old Jan 8, 2006 | 05:33 PM
HiProfile's Avatar
Default Re: (mrbsponge)
I wouldn't disagree with piping oil lines, but wtf was that guy thinking? I wonder if he ever heard of a distribution block? He'd have saved a shitload of parts, time, and space.
I'd also suggest compression fittings, rather than flares. They're cheap, easy to seal/install, reusable (to a degree) and are good for more oil psi than your motor will put out.
Old Jan 8, 2006 | 07:05 PM
crx12's Avatar
Default Re: (HiProfile)
Man there must be a gallon of brake fluid sitting in those lines. Sorry couldn't resist.
Seriously though, I think it's fine and cheaper than stainless but I wouldn't do it that way.
Old Jan 8, 2006 | 07:29 PM
Kelly.'s Avatar
I've quit using this account
it looks ok,
i wouldnt do it, only because it would a pain in the *** to work on.
