turbo rebuilding
Old Jan 9, 2006 | 08:18 AM
huge230's Avatar
Default turbo rebuilding
do those cheap ebay turbo rebuld kist actually rebuild turbos? Im just learnign about turbos and those kits seam too cheap to actually rebuild a turbo. like 80 dollars.
Old Jan 9, 2006 | 02:46 PM
zeroice's Avatar
Default Re: turbo rebuilding (huge230)
it does rebuild a turbo but i wouldnt do it yourself if it were me. Need to have the trubo rebalanced.
Old Jan 9, 2006 | 03:20 PM
huge230's Avatar
Default Re: turbo rebuilding (zeroice)
ok but that is all the parts that are replaced? what part is removed that makes it unbalanced? thanks
Old Jan 9, 2006 | 03:23 PM
AbitAvenger's Avatar
Have it professionally done
Old Jan 9, 2006 | 04:37 PM
huge230's Avatar
Default Re: (AbitAvenger)
ya wasnt planning on doing it myself, just trying to learn
Old Jan 9, 2006 | 06:26 PM
G2turbo_terror's Avatar
Shops will do balancing, I've never heard it costing over 50.
Old Jan 10, 2006 | 04:11 AM
zeroice's Avatar
main things are 2 bearings, retaining clips that hold them in place, 2 oil seals depending on which kind of turbo and seal you will use. 2 gaskets. What makes the turbo unbalanced is when you take the fin/blade off the shaft on the air inlet side. Anybody correct me if i am wrong....
Old Jan 10, 2006 | 08:26 AM
SL0WEGG's Avatar
i have actually taken off the compressor wheel without marking it and put it back on and the turbo was fine, but that was a cheap nissan turbo.
1993acuraintgralsvtec
Apr 14, 2004 08:37 PM
nigel
Apr 5, 2004 12:46 PM
Hoosier Daddy
Mar 24, 2004 01:20 PM
SIK IN DA HED
Feb 11, 2004 11:58 PM
