b18 block
Old Jan 7, 2006 | 02:34 PM
red beast's Avatar
Default b18 block
how much boost can i run without sleeving the block and can i make 360 hp sucessfully
Old Jan 7, 2006 | 02:37 PM
s2kdre's Avatar
Default Re: b18 block (red beast)
u could run 300whp on a completely stock block, i've seen 600whp on stock sleeves, but its always good to sleeve a block if u want 450hp plus,
Old Jan 7, 2006 | 02:44 PM
red beast's Avatar
360-380 should be good for now as i plan on building a different motor. but now i on a budget
Old Jan 7, 2006 | 05:44 PM
BlueShadow's Avatar
Default Re: (red beast)
One thing that a lot of people do if they're on a budgeet is stay with stock sleeves, but aftermarket pistons and rods, and headstuds. With all stock internals a lot of people will say that 300HP is the safe limit, and more and you're pushing your luck. However if you upgrade the internals, then you have a setup that can make up to 400-600HP. If you check out evans-tunung.com you'll see that Jeff Evans has tuned quite a few stock sleeve/upgraded internal B series. AFAIK the highest he's been able to get out of that type of setup was 640-something WHP.
thugsbryan
Mar 27, 2015 09:48 AM
Leric
Jul 23, 2013 08:12 AM
GT500FTW
May 16, 2013 10:27 AM
slammedbbs
Jun 6, 2011 09:32 AM
87turdR
May 6, 2005 01:21 AM
