compression and leakdown test results
Old Jan 8, 2006 | 08:27 PM
debogsr's Avatar
Default compression and leakdown test results
Compression Test Results
Cylinder 1 = 210 psi
Cylinder 2 = 210 psi
Cylinder 3 = 190 psi
Cylinder 4 = 210 psi
Leakdown Test Results
Cylinder 1 = 4%
Cylinder 2 = 4%
Cylinder 3 = 13%
Cylinder 4 = 4%
its a 95 GSR with 150K
JRSC @ 8 PSI tuned with hondata
Car has a real bad hesitation/stutter at WOT. Im not sure if its related to these results posted but maybe someone can help me with that.
I couldnt hear where the air was coming from on the third cylinder. I kinda heard some air from the adjacent spark plug hole but im not positive. I took off the radiator cap and there were no bubbles. I also bought one of those coolant testers from kragen and tested for gasoline gasses in my coolant and it came out negative.
Any help is greated appreciated.
Thanks!
Does this mean my headgasket is ok?
Old Jan 8, 2006 | 08:56 PM
urbansi's Avatar
Default Re: compression and leakdown test results (debogsr)
If your headgasket was bad i dont think your compression would be that high, leak down tests mainly test valves and your piston rings. Your numbers seem fine aside from the 20psi difference in cyliner 3, not something to get too worried about, unless the numbers durasticly change shortly. keep doing the tests atleast every month, also if the head gasket was bad the coolant would most likley be milkey, and you would see the smoke from the tail pipe.
Old Jan 8, 2006 | 10:02 PM
debogsr's Avatar
Default Re: compression and leakdown test results (urbansi)
oh i am definitly seeing smoke, but i think its black (due to all the black stuff on my bumper) Do you think those numbers could be valves? or my rings going bad?
I dont think it is the headgasket either because of the coolant test i did. I changed my oil last night and it wasnt milky at all so, yeah....
THanks for the reply.
Old Jan 8, 2006 | 10:06 PM
komat's Avatar
i had alot of black stuff covering my rear bumper when my ringlands was going out
Old Jan 8, 2006 | 10:08 PM
andysila's Avatar
good compression
Old Jan 8, 2006 | 10:23 PM
debogsr's Avatar
Default Re: (andysila)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andysila &raquo;</TD></TR><TR><TD CLASS="quote">good compression </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">i had alot of black stuff covering my rear bumper when my ringlands was going out</TD></TR></TABLE>
thanks for your help. Did your compression result like mine?
Old Jan 8, 2006 | 11:25 PM
komat's Avatar
Default Re: (debogsr)
compression b4 i blew the motor was
190 210 205 200
at 10psi i blew all 4 ringlands
compression showed up at
190 150 30 190
Old Jan 8, 2006 | 11:58 PM
racinskittle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi &raquo;</TD></TR><TR><TD CLASS="quote">If your headgasket was bad i dont think your compression would be that high</TD></TR></TABLE>
Ok and that would be incorrect then.
Your compression test will come out fine a lot of times if your headgasket is blown.
Old Jan 9, 2006 | 12:02 PM
eg:R's Avatar
can i do a leak down test with just the block by itself or does the head have to be on the block also??
Old Jan 9, 2006 | 12:35 PM
debogsr's Avatar
Default Re: (eg:R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg:R &raquo;</TD></TR><TR><TD CLASS="quote">can i do a leak down test with just the block by itself or does the head have to be on the block also??</TD></TR></TABLE>
thread hijacker...
Do you know what and how a leakdown test is? the answer to your question is no, but do a search.
blackeg
Nov 23, 2013 06:06 PM
delsolo95
Apr 3, 2013 08:49 AM
aznxpyroboi
Dec 9, 2007 10:09 PM
Tyteg
May 16, 2007 07:30 AM
Chubz
Jun 27, 2002 02:00 PM
