y8 turbo and keep a/c???
Old Dec 8, 2006 | 10:15 PM
SoullessJapaneseMachine's Avatar
Default y8 turbo and keep a/c???
ive been hearing that you cant expect to keep a/c if turboing a y8...or at least not if you dont relocate the compressor or whatnot...
is there any combination of exhaust mani + dsm turbo (14b...t25) that will clear the a/c comp on a y8 (and clear everything else at the same time)
for example, will hf mani + t25 clear a/c?
help an FI newbie out
Old Dec 9, 2006 | 08:27 AM
platinum00's Avatar
Default Re: y8 turbo and keep a/c??? (SoullessJapaneseMachine)
there are tons of kits that keep the AC on the y8.
greddy, eddelbroke, and i believe your hf mani will fit without removing AC.
when you start getting into the larger turbo's you might have issues.
platinum.
Old Dec 9, 2006 | 08:38 AM
igo4bmx's Avatar
usually you will have to remove the fan, and run a slim pushed fan in front of the condensor.
i'm running a ram horn style, precision sc50 with a/c
Old Dec 9, 2006 | 11:16 AM
oscarmayer's Avatar
^ yes excepot unless your using the greddy kit that is designed to work on a total stock setup.
Vtakkk
Jul 4, 2006 04:53 PM
BoostNEF
Apr 9, 2005 07:55 AM
spooned-ek
Feb 5, 2004 12:45 PM
ITSTOCK
Nov 30, 2003 12:06 PM
solsteeler
May 16, 2003 07:44 AM
