Air / Fuel after throttle lift - Is this normal >> ?
When I let off the throttle my A/F goes threw the roof. It comes right back down to normal, but seems odd that motor would run that lean for sec...
Here is a log of what is going on when going to 2k RPM and letting off.
thanks,
platinum
thanks,
platinum
Re: Air / Fuel after throttle lift - Is this normal >> ? (Lonnieboosted)
So is the motor really runing that lean, or is it just cause the gas gets sucked out of the exhaust during lift?
platinum
platinum
Re: Air / Fuel after throttle lift - Is this normal >> ? (Muckman)
No for sure not part throttle. A/F looks fine during throttle and boost.
I guess it's the injectors shuting off when decelerating.
Learn something everyday from you guys.
thank you,
platinum
thank you,
platinum
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">The injectors shut off completely when your decelerating off the throttle completely. However if your at part throttle and its that lean then you have a problem.</TD></TR></TABLE>
hit the nail on the head
Re: Air / Fuel after throttle lift - Is this normal >> ? (platinum00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 »</TD></TR><TR><TD CLASS="quote">No for sure not part throttle. A/F looks fine during throttle and boost.
thank you,
platinum</TD></TR></TABLE>
Thats it! I noticed when i let off my Wideband would go nuts!! Like -x38 past 1:100 AFR lol!
thank you,
thats normal man
that means the ecu cut off the duty cycle on the injectors to a point it will lean
the amount of fuel and air consumed by the engine is minimal and poses no threat to the engine
everytime i datalog my air fuels during shifts it also climbs up to 21 afr's and goes back to normal
Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">That is why when you datalog, you set a min TPS, so you don't get those big spikes in the A/F. </TD></TR></TABLE>
is this in the EMS software?
platinum
platinum
Re: (platinum00)
thats wierd, cause when I let go of the gas/shift my A/F goes rich. It will read rich for like 2-3 seconds THEN go lean. Its wierd cause when im driving, I shift from 2nd and the a/f goes rich then go into 3rd, if I shift fast the a/f is still rich and when I give it some gas in 3rd it'll make a small pop. It does this just about every time in every gear.
I'm running crome with the plx m300.
pohaku
10-01-2007 01:04 PM
LSVTEC 91 Civic
15
10-28-2005 06:16 PM
shamoo
06-18-2002 12:07 PM
