reasonable boost limits for built H22 on pump/E85
Old Dec 15, 2006 | 02:04 PM
purpleh22's Avatar
Default reasonable boost limits for built H22 on pump/E85
H22, Arias 10:1, sleeved, Crower rods, S300, MSD 6AL, HVC Blaster, GT30 w .82a/r, GE intake, 950cc Precision inj., JG head, 3" ex from turbo back etc.
I'm running 16psi and 11 psi off a Blitz ebc. On a Mustang dyno it's producing 465 whp and 344 wtq. at the 16 psi setting. Because of the higher compression I have been using 120 race gas (113) octane, all the time. The 92 hatch is street driven only.
How much boost is reasonable for a setup like this on pump gas? E85?
I know it varies from engine to engine and from one setup to another but would it be ridiculous to try to run it on the street @ 16 psi with pump/E85?
I'd like to know - before I go in for another dyno tune.
Currently staying under 18 for timing and below afr under 11.8, when in boost.
Modified by purpleh22 at 1:05 PM 12/16/2006
Old Dec 16, 2006 | 12:06 PM
purpleh22's Avatar
Default Re: reasonable boost limits for built H22 on pump/E85 (purpleh22)
Any opinions/guesses?
Old Dec 16, 2006 | 01:54 PM
boosted92's Avatar
16 psi on E85 with your compression will be a walk in the park. A good tuner could probably tune your 10:1 motor at 16 psi on regular 93/94 octane without knock.
Servion just tuned a TT Mustang that made 1100 RWHP with 85 on a Dynapack through a powerglide (sucks a lot more power than a standard) and I've seen another mustang dyno at over 1000 RWHP and 30 pounds of boost on E85. It's very potent stuff.
Old Dec 16, 2006 | 03:53 PM
purpleh22's Avatar
Default Re: reasonable boost limits for built H22 on pump/E85 (boosted92)
Thanks, sounds like it will be worthwhile for me to go with E/85. Even with the 1/3 increase in fuel use I'd save around $2 for every 25 mi. of driving.
purpleh22
Mar 16, 2007 09:58 AM
purpleh22
Mar 10, 2006 09:12 PM
purpleh22
Jan 12, 2006 04:36 PM
purpleh22
Jan 11, 2006 12:25 PM
prelude1911
Dec 14, 2005 10:04 AM
