Post up your pics of fuel pump mount shots....
Guest
Posts: n/a
Ive been debating where to finally mount my pump. I have it mounted but dont like the placement. I dont want it to be starved for fuel. Check out these pics below and tell me which is better.
This one is the way I have it mounted now...will it work fine? This isnt my car but it is what I went off of when mounting it.
Or something like BoostedJeff's even tho he remounted it. Dont know if he has posted pics of the new mount job but which of the 2 would work better?
Just two different car/mount setups for opinions. Which one do you all like better.
Thanks in advance guys/gals
Modified by cuin9sec at 7:32 PM 12/8/2006
Re: Post up your pics of fuel pump mount shots.... (cuin9sec)
i have question about those sump setups. do you really need a sump welded or can i just poke a hole and put in a AN fitting to the pump. i won't run my car low on gas just curious, we'll even if i did that i would still have to weld that fitting in stupid idea i guess. i just don't want to drop the tank. yeah i know even if i drill the spark might ignite the vapor in there oops dangerious. yeah i better drop the tank
Guest
Posts: n/a
Re: Post up your pics of fuel pump mount shots.... (speedlabx2005)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedlabx2005 »</TD></TR><TR><TD CLASS="quote">i have question about those sump setups. do you really need a sump welded or can i just poke a hole and put in a AN fitting to the pump. i won't run my car low on gas just curious, we'll even if i did that i would still have to weld that fitting in stupid idea i guess. i just don't want to drop the tank. yeah i know even if i drill the spark might ignite the vapor in there oops dangerious. yeah i better drop the tank</TD></TR></TABLE>
drop the tank and get it over with. please weld on a sump. lol come to think of it...i wonder how many people have just poked a hole for a sump? haha
Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge »</TD></TR><TR><TD CLASS="quote">i will be doing mine tomorrow</TD></TR></TABLE>
Send me pictures then You know how we do in Florida, lol
-- Alpha
-- Alpha
Guest
Posts: n/a
Re: (mrbsponge)
you going to do it like one of the pics above?
Re: (cuin9sec)
Just remember that aeromotive pumps are gravity feed. You would want the feed line to be higher than the pump. I had a problem with my aero 1000 mounted the second way, so I kept the mounting position but went with a Weldon pump. Oh btw GET YA SOME
Guest
Posts: n/a
Re: (Lonnieboosted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lonnieboosted »</TD></TR><TR><TD CLASS="quote">Just remember that aeromotive pumps are gravity feed. You would want the feed line to be higher than the pump. I had a problem with my aero 1000 mounted the second way, so I kept the mounting position but went with a Weldon pump. Oh btw GET YA SOME</TD></TR></TABLE>
lol....thanks man. I knew they were gravity fed but the way its mounted in the 1st pic it is still somewhat below the sump outlet. i guess ill leave it that way...OR go with a weldon. Do you have a link for a good deal on a weldon pump?
Re: (BoostedJeff)
ha thats my car in the first pic
i used a bracket mounted to the frame and rubber spacers between the pump and bracket to lower the pump to the bottom of the tank,
i have run the car till empty everyday driving but at the track i put aleast half a tank and its been fine.ialso drilled a vent hole in my gas cap to stop the tank from pressurizing and splashing the fuel around and sucking air bubbles.
i also have the eliminator pump so its a little beefier then the a1000
Modified by swapit at 11:10 AM 12/9/2006
Guest
Posts: n/a
Re: (swapit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swapit »</TD></TR><TR><TD CLASS="quote">ha thats my car in the first pic
Modified by swapit at 11:10 AM 12/9/2006</TD></TR></TABLE>
so it worked fine for you? thats the way i have it mounted now. if it worked fine then ill just leave it.
like the way you remounted yours jeff. looks good.
as for peters...it does look a little higher then it needs to be but if it works then i shouldnt be soooo worried.
thanks guys
thanks guys
everyone talks about how the pump has to be lower then the sump but wouldnt it just need to have the fuel level above the pump and not where the sump is? wouldnt it use gravity pressure and such to keep fuel in the line?
Re: (BoostedJeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff »</TD></TR><TR><TD CLASS="quote">i remounted mine since the pics above, i used 3/4inch teflon round stock just to make the pump a little more even with the sump.
</TD></TR></TABLE>Your left Jack Stand kicks ***
Re: (BoostedJeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff »</TD></TR><TR><TD CLASS="quote">^^ has he ran it like that yet?
seems like that feed from the sump to pump would cause issues</TD></TR></TABLE>
Yup ran it dynoed 883 with the pump sitting there!!
Re: (B18c1turboedEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18c1turboedEK »</TD></TR><TR><TD CLASS="quote">
Yup ran it dynoed 883 with the pump sitting there!! </TD></TR></TABLE>
looks like hes running 2 pumps?
