car smoking need help
Old Dec 9, 2006 | 10:24 PM
snaileg's Avatar
Default car smoking need help
well my car smokes sometimes at idle and has smoked 1 time when i left a gas station but all the cylinders are firing if a ringland broke then 1 cylinder would not be working correct... since the cylinder wall would be messed up because it smoked like three times so far but if it does it doesnt do it for long only like a minute or two so i was wondering if it could be the valve that i tapped my oil pan to and the oil is going back up and sucking in oil and burning more...
Old Dec 10, 2006 | 12:04 AM
A.E Motoring's Avatar
Default Re: car smoking need help (snaileg)
do a compression test, that will at least tell u if u have a cylinder down, it could also be blown turbo seals, just do a comp test and go from there.
here is a link that i enclosed just incase u needed it
http://www.c-speedracing.com/h...t.php
Old Dec 10, 2006 | 10:21 AM
snaileg's Avatar
Default Re: car smoking need help (Dual Cam Racing)
alrite thanks man for the help but also if a cylinder was down wouldnt it sound like a scoobey?
Old Dec 10, 2006 | 10:23 AM
CRXdan's Avatar
I dont think you want any car sounding like scooby.
BUt yes if one cylinder is blown it would run on 3 cylinders giving you a boxer engine sound. What color is the smoke? Are you runnign an oil restrictor on your turbo? How old is the motor? blah blah
Old Dec 10, 2006 | 10:32 AM
snaileg's Avatar
my motor is a built piston/rod just got done about 2 weeks ago no oil restritor and the smoke is white and if a cylinder was down wouldnt clouds of smoke come out from the exhaust under high acceleration because mine doesnt only at idle and not driving or if i driver like 50 yards then its gone if it is smoking because im pretty sure running on 3 cylinders the car would smoke all the time just about
Old Dec 10, 2006 | 04:39 PM
snaileg's Avatar
would a blown headgasket cause the smoking from the exhaust for a little while and then it goes away and when i get on it after it warms up it doesnt smoke and it smokes from the engine bay when i let sit and idle and all 4 cylinders are firing so that means no ringlands are broken and the coolant is all gone when i checked it and had to poor more in but still no compression test yet until tomorrow when i get to work so do you guys think it would be a headgasket?
Old Dec 10, 2006 | 05:14 PM
00BoostedGSR's Avatar
sounds like maybe a turbo seal. Are you blowin whiteish gray smoke.
If the compression test and leak down down test are good, then i would say most likely a seal.
Old Dec 10, 2006 | 05:16 PM
snaileg's Avatar
ya whiteish gray smoke but when it warms up no smoke and when you get on it no smoke =\
Old Dec 10, 2006 | 05:22 PM
Default Re: (snaileg)
seriously, only way to find out is to do the tests, thats all u can do right now, us just guessing wat it is isn't going to tell u anything untill u do the test and let us know the results, its just a big guessing game right now
Old Dec 10, 2006 | 05:42 PM
snaileg's Avatar
ya im sorry guys but wish me luck tomorrow when i get to work ima do it i hope it turns out good =\
Old Dec 11, 2006 | 08:55 PM
Boosted B6teen's Avatar
Man your **** was blown You filled the shop up with smoke, I could hardly breath
Old Dec 12, 2006 | 10:46 AM
snaileg's Avatar
Default Re: (Boosted B6teen)
its allliiiiivvvvveeeeeee lol yay
Old Dec 13, 2006 | 08:36 AM
snaileg's Avatar
compression test went good 180 all across and about 2 days after the compression test it smoked again from the exhaust when i went to go air up my drag radials and then i checked coolant and it was empty again after i had just refilled it 2 days before and when i rev at a stop it smokes even more but then when drive no more smoke... could it be the turbo going out? also it doesn't smoke at every stop just that one time at the gas station and leaving the gas station
Old Dec 13, 2006 | 09:12 AM
SOHC_MShue's Avatar
if you let it sit at idle for a little while will it start smoking? Sounds like turbo seals to me.
Old Dec 13, 2006 | 10:36 AM
snaileg's Avatar
ya just sitting there at idle it will smoke but today i got into boost 1 time then 15 mins later i went to teh gas station to fill in air and it was smoking bad and its white smoke like coolant and my coolant was gone out of the bottle and i had filled it up 2 days before so you guys think its turbo seals?
Old Dec 13, 2006 | 03:52 PM
snaileg's Avatar
need help!!!
Old Dec 13, 2006 | 04:52 PM
orange99si's Avatar
Sounds like coolant is getting into one of your cylinders.
I put a cometic low comp. head gasket in about 3-5 months ago and now my car does the same thing. At start it will smoke at idle, but then Ill let it sit and warm up for a couple of min and no more smoking, and when I get in it , no smoke neither.
I also have to add coolant about every week-week and a half, I did a pressure test and had no external coolant leaks, so it has to be leaking internally.
Oh ya I get some rough idle too at start ups
Old Dec 13, 2006 | 05:42 PM
snaileg's Avatar
if coolant got into the cylinders then my motor would be messed up which would mean also a compression leak and then my compression test would not come out 180 all across and 1 cylinder would be down or depending on how many is filled with coolant so that cant be possible tomorrow when i get some day light i will need to check out the turbo seals
Old Dec 15, 2006 | 11:37 PM
LsCivic18's Avatar
IT Has To Be Your HeadGasket. My Car Did The Samething Before I Had it Rebuild. Is It Hard To Start? Are Your Spark Plugs Still Good?
Joser_8051218
Jul 5, 2014 12:22 PM
evotux
Nov 20, 2006 07:01 PM
98B18C1
Jul 3, 2006 07:32 PM
soon2b
Oct 4, 2004 05:46 PM
integra_gsr98
Mar 23, 2004 02:50 PM
