high egt. didnt change anything on car
suddenly, once it started getting really cold, unitl my car warms up, it looks liek i have really high egt. like 600+ degrees celicius at idle. i didnt change anything int he setup. only thinkg i can think of is maybe its so cold, the unit is malfunctioning. would the tune have any part in this, even though nothing has changed?
Re: high egt. didnt change anything on car (playahwitgame)
well cold air is more dense, so you can cram more air in with less boost. this can cause you to run more lean and run a higher egt. I always turn boost down when its cold out because of this.
But in your situation try another unit, or test your gauge in a friends car. If the unit is ok id call the tuner. good luck
edit: corrected by 93supercoupe
Modified by memorybox at 11:59 AM 12/10/2006
02CivicEXPhilly
Honda Civic (2001 - 2005)
07-01-2008 04:54 AM
The_Head
12-15-2002 11:28 AM
