arp hardware???
Old Dec 11, 2006 | 07:59 AM
crvtkllr's Avatar
Default arp hardware???
so i built a b16t with all arp hardware, the motor now has fried piston rings with about 14k miles on 12psi.
my ? is can i reuse the head studs, rod bolts and main studs or are they torque to yeild bolts
need lots of help thanxs
Old Dec 11, 2006 | 08:46 AM
crvtkllr's Avatar
Default Re: arp hardware??? (crvtkllr)
how bout a bump??
Old Dec 11, 2006 | 09:49 AM
delslo93's Avatar
People reuse arp headstuds all the time. I'm not sure about the mains and the rod bolts though but I believe you can reuse them since they don't stretch when torqued unless I'm wrong.
Old Dec 11, 2006 | 02:04 PM
crvtkllr's Avatar
Default Re: arp hardware??? (delslo93)
so can anyone back delslo up on this one ????
Old Dec 11, 2006 | 02:14 PM
Speed Infliction's Avatar
reuse them hoes
Old Dec 11, 2006 | 02:40 PM
crvtkllr's Avatar
Default Re: arp hardware??? (Speed Infliction)
should i torque them a bit tighter since they might be stretched??
Old Dec 11, 2006 | 03:32 PM
dr_latino999's Avatar
I don't, I re-torque the head studs to the recommend ARP values, the Rod bolts should be measured and installed using one of those nifty Stretch Gauges, and for the mains I would treat them just the same as the head studs.
Old Dec 12, 2006 | 05:29 AM
delslo93's Avatar
Default Re: arp hardware??? (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">I don't, I re-torque the head studs to the recommend ARP values, the Rod bolts should be measured and installed using one of those nifty Stretch Gauges, and for the mains I would treat them just the same as the head studs.</TD></TR></TABLE>
Word...just retorque them to what they're suppose to be and be done with it. Should be fine.
kornerk12
13
Aug 7, 2009 02:46 PM
THC07
13
Mar 29, 2007 06:54 PM
Civichatch2k
Dec 27, 2004 10:42 AM
ranta18
Sep 1, 2003 01:00 PM
