missing link
Old Dec 8, 2006 | 10:47 PM
b18bteg14's Avatar
Default missing link
getting ready to turbo...is a missing link needed to pass emissions and will it help the performance of the turbo kit as a whole? thanks
Old Dec 10, 2006 | 11:00 AM
b18bteg14's Avatar
Default Re: missing link (b18bteg14)
bump
Old Dec 10, 2006 | 11:37 AM
boostedcivicsir's Avatar
Mr. Badwrench
what are you using for management? if it is an FMU only, without a chip or any kind of management, you will need the missing link.
Old Dec 10, 2006 | 11:41 AM
b18bteg14's Avatar
Default Re: missing link (boostedcivicsir)
well i was actually just posting in another topic about fmu/fuel pump/afc hack. i was planning on just running an fmu and upgraded fuel pump for 8-10 psi, but i was told i should run larger injectors and do the AFC hack if i wanted to run an fmu. Would running just the fmu, fuel pump, and missing link be suitable for 8-10 psi?
Old Dec 10, 2006 | 11:54 AM
Hondoctors's Avatar
We've run 12:1 FMU, stock injectors, Walbro 255LPH HP, and missing link with 6-8 lbs boost with great success. Running higher than 8 psi is risky, and we put everything on engine management after that.
Old Dec 10, 2006 | 11:57 AM
b18bteg14's Avatar
ok well the wastegate is set at 8 now. did you run this on an ls? what kind of numbers did you make?
Old Dec 10, 2006 | 02:22 PM
b18bteg14's Avatar
i dont understand though, wouldnt the fmu dump too much fuel in at low rpm, making you lose power?
Old Dec 10, 2006 | 02:43 PM
Oyvind Ryeng's Avatar
Default Re: (b18bteg14)
To my understanding, the FMU doesn't add fuel pressure when in vacuum.
And since nobody else have said it yet:
Chip your ECU for Uberdata/Crome/Whatever and get it tuned on a dyno! Your ringlands will thank you.
Old Dec 10, 2006 | 02:45 PM
CustomX113's Avatar
Banned
only ups the fuel pressure under boost
Old Dec 10, 2006 | 02:46 PM
b18bteg14's Avatar
yea but i thought once the fmu does add fuel it adds it at one rate over the entire rpm band...that doesnt seem very efficient
raysjdmh22a
Mar 17, 2006 07:01 PM
Sohc Driver
Sep 15, 2003 10:54 AM
inspyral
Jul 24, 2002 01:51 AM
