Who makes the largest throttle bodies?
I'm trying to find the LARGEST throttle body with the Honda OEM 4 bolt pattern that will be a direct bolt-on without any modifications...anyone know whats the biggest that they make.
I'm really 2slow
Re: Who makes the largest throttle bodies? (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg »</TD></TR><TR><TD CLASS="quote">you can get the mustang adapter plate from edlebrock and use whatever you want.</TD></TR></TABLE> talk to ghostworks. he runs a 4" I believe.
Re: (Boostfed.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com »</TD></TR><TR><TD CLASS="quote">I can get RPM Services 76mm TBs , I just got one for my car actually </TD></TR></TABLE>
Re: (ProjectBoosted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectBoosted »</TD></TR><TR><TD CLASS="quote">ericks racing makes a 78mm there is a guy selling one on nwstreetracing.com in the engine section he wants $300</TD></TR></TABLE>
I am NOT POSITIVE BUT I do believe that is the same as the RPM Services 76mm TB, it is a 78mm opening to 76mm Butterfly.
trapped in my own room!
Re: (HNLV)
camp1320.com has 78mm RPM serivce T bodies. $275 bolt on give tom a call im sure he will hook you up.!! full warranty no questions asked thru Tom
Re: (PHDZINE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHDZINE »</TD></TR><TR><TD CLASS="quote">Cool...thanks guys.</TD></TR></TABLE>
paul, hit up thomas (camp1320), he has the rpm 78mm's
Re: (wHOAlly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wHOAlly »</TD></TR><TR><TD CLASS="quote">
paul, hit up thomas (camp1320), he has the rpm 78mm's </TD></TR></TABLE>
Sure will...he usually he has all the good stuff in stock.
Thanks!
Thanks!
Re: (PHDZINE)
you know to call us first.... bet alot of people on h-t doesnt know that the 78mm exist ... bolt on to stock honda bolt pattern
78mm bolt on t-bodies for honda acura give us a call..!!
Re: (Boostfed.com)
I am NOT POSITIVE BUT I do believe that is the same as the RPM Services 76mm TB, it is a 78mm opening to 76mm Butterfly. </TD></TR></TABLE>
you are correct terry....
if you guys need some please feel free to call us anytime we are open very late for the holidays to try to get all orders out for christmas so feel free to call anytime we might still be at the shop
Re: (camp1320.com)
Thanks Thomas for the great price on the 78mm thorttle body and for all the grub at your end of year Xmas sale.
Re: (PHDZINE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHDZINE »</TD></TR><TR><TD CLASS="quote">Thanks Thomas for the great price on the 78mm thorttle body and for all the grub at your end of year Xmas sale.</TD></TR></TABLE>
no sweat.. you got any pics of it or do i have to take some
Re: (camp1320.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camp1320.com »</TD></TR><TR><TD CLASS="quote">
no sweat.. you got any pics of it or do i have to take some </TD></TR></TABLE>
i wanna see pics of that thing....
Re: (97grnrs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs »</TD></TR><TR><TD CLASS="quote">is the bigger the TB the better with forced induction or is there a limit? </TD></TR></TABLE>
Most people trying to make BIG HP are going with 3" charge piping so you want to get as close to matching up the charge piping to TB sizing, 3"= 76.12mm I do believe.
Last year I dynoed my old set up with 2.5" charge pipes and a 65mm TB made 711whp with 35psi, Tony1 suggested going to 3" charge pipes BIGGER TB, we had a 70mm TB to go on anyways and the piping needing to be welded. The set up made 714whp with now only 32psi so TB and IC pipe size makes a difference
I also asked Tony Palo what he felt the need for 3" piping was and he stated he felt anything over 400whp would benefit from it BUT at the time I do not thing he had ever tested it or not. Maybe he will chime in
Re: (Boostfed.com)
For what it's worth, a 3" pipe flows a lot more than a 3" throttle body. The throttle blade and shaft disrupts the airflow through the center quite a bit. If you're running 3" piping, a t/b bigger than 3" will help, assuming you're making enough power to need it. Also, bends create flow losses. A 3" 90deg bend has more restriction than a 3" straight tube, so even though your 3" t/b won't flow as much as a 3" pipe, doesn't mean there's no need to do 3" piping if you have a 3" t/b. The losses through the intercooler piping as a whole will be less, which will make more power. I run 3" piping on anything over 450ish hp. There's more or less no downside. The amount of time it takes to fill a 3" pipe compared to a 2.5" pipe is so small, it is almost not noticable.
