where do i get this gasket?
Old Dec 12, 2006 | 10:32 AM
tegasaurus's Avatar
Default where do i get this gasket?
took the compressor cover off... that little rubber ring expanded for some reason and now the **** won't go back in! where do i get a new one? this is for a turbonetics t3/t4 .63 turbing .60 compressor 57 trim.
thx
Old Dec 12, 2006 | 11:02 AM
aryiman98civic's Avatar
did you try to contact the manufacturer to see if they had any they could send you? that would be the first thing i would try
Old Dec 12, 2006 | 11:25 AM
tegasaurus's Avatar
Default Re: (aryiman98civic)
no, i figured they'd take forever to send me one so i'd like to find maybe a local place or an HT sponsor -- i'm very impatient when it comes to ordering things.
Old Dec 12, 2006 | 11:46 AM
HamiltonRex's Avatar
Default Re: (tegasaurus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote"> i'm very impatient when it comes to ordering things </TD></TR></TABLE>
Then just buy a new turbo. contact the mfg.
Old Dec 12, 2006 | 11:48 AM
EJ1 wilcox's Avatar
Default Re: (HamiltonRex)
I've seen them on eBay before
Old Dec 12, 2006 | 11:54 AM
fast is fun's Avatar
Default Re: where do i get this gasket? (tegasaurus)
They are ready available through any large turbo manufacture... I would try precision turbo, turbos direct, or turbonetics... They expand like that from being exposed to excessive amounts of oil.. If you are in az, there ar plenty of rep. sources to get them from..
Old Dec 12, 2006 | 12:52 PM
Finland's Avatar
stick it in the freezer to see if it shrinks up..
Old Dec 12, 2006 | 12:56 PM
SPOOLINmatt's Avatar
Default Re: (Mr. Helsinki)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Helsinki &raquo;</TD></TR><TR><TD CLASS="quote">stick it in the freezer to see if it shrinks up..</TD></TR></TABLE>
that or use grey RTV Sealant, Ive found myself using that on some turbos, a thin layer goes on smoothly and comes off smooth, takes 2 minutes to clean out the old if you ahve to seperate the housings.
Old Dec 12, 2006 | 01:37 PM
tegasaurus's Avatar
Default Re: (SPOOLINmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast is fun &raquo;</TD></TR><TR><TD CLASS="quote"> They are ready available through any large turbo manufacture... I would try precision turbo, turbos direct, or turbonetics... They expand like that from being exposed to excessive amounts of oil.. If you are in az, there ar plenty of rep. sources to get them from..</TD></TR></TABLE>
should i be concerned about the excessive amounts of oil thing? i did buy the turbo used off a member here on HT.. hope i didn't get screwed
tried that. didn't work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt &raquo;</TD></TR><TR><TD CLASS="quote">
that or use grey RTV Sealant, Ive found myself using that on some turbos, a thin layer goes on smoothly and comes off smooth, takes 2 minutes to clean out the old if you ahve to seperate the housings.</TD></TR></TABLE>
are you serious? is that safe to do?
Old Dec 12, 2006 | 08:08 PM
ive never had a problem and i cannot forsee a resaon or how something could happen.
Vagitarian
Oct 9, 2012 06:53 AM
superfuji57
Jul 8, 2007 05:24 PM
Cloner
Jun 11, 2005 05:04 PM
ExploitedRacing-HR
Welding / Fabrication
13
Jan 28, 2005 03:34 PM
5thgencivic
Oct 12, 2004 06:40 PM
