Moates Wideband O2
Anyone use it or have had experience with it?
or the LC-1 Lambda Cable with O2 sensor?
Is there a big difference between the two? Will they both do the same job on my homemade turbo setup?
http://www.moates.net/index.php?cPath=48
The O-meter is a display and datalogging attachment to the LC-1. The LC-1 with sensor is probably the least expensive standalone wideband you can get, even cheaper than the DIY kits. For $200 you can have everything you need to run a wideband with a standalone ECU: MegaSquirt, AEM, chipped ECU, etc. The O-meter is superfluous if you are using a standalone because you will be able to see the lambda on your laptop anyway.
baulum
Engine Management and Tuning
Jan 14, 2010 11:14 PM
