gsr setup good?
Old Dec 9, 2006 | 12:04 AM
94egcoupeturbo88's Avatar
Default gsr setup good?
Srp turbo/nitrous pistons, eagle 4340 race crank, eagle h beam rods, JE turbo/nitrous piston rings..the kit says can handle 30 pounds of boost compression ratio 9.0
with a turbonetics t3-t4 turbo
do i need a low compression head gasket for the gsr? if so and u have one let me know how much
is there anything else i need to do?
please help trieng to get the car on the road by february
Old Dec 9, 2006 | 04:31 AM
Mugencrxsir1's Avatar
Default Re: gsr setup good? (94egcoupeturbo88)
Stock head gasket will work just fine, if you have a larger bore, then pick up a modified stock head gasket from Golden Eagle. They also copper spray the HG's they send out!
Old Dec 9, 2006 | 05:41 AM
sc4dr's Avatar
I would forgo the crank, and run cp pistons, and eagle rods. Cometic gaskets have always worked well for me. You can make up for a smaller discplacement with more boost, and a proper tune. Basically, don't spend more than you have to.
Old Dec 9, 2006 | 07:13 AM
Well i already have the pistons, crank, and rods i just figured that since the bottom end is low compression the head would have to be to but with the low compression head gasket what would be a safe psi to run?
Old Dec 9, 2006 | 01:00 PM
sc4dr's Avatar
Run a stock sized headgasket, your cr ratio is fine, and you should be able to boost as much as your turbo can produce.(as long your tuner is comfortable with it). What stroke is your crank? I'm running a 95mm eagle crank in my gsr. You or your engine builder will probably have to notch the bottom of your cylinders to give clearence for your rods, you might also have to remove your oil jets, and weld shut to allow clearence for the new crank.
tremblay
Oct 27, 2009 05:03 PM
calumthestrong
23
Jul 7, 2009 08:01 AM
kulba
Jan 29, 2007 07:19 PM
AllMotorITR
Jan 13, 2002 12:41 AM
