car's blow off valve sounds different all of a sudden
94 honda civic cx
jdm d16a sohc vtec
t3/t4 turbo w/ front mount intercooler
universal blow off valve
rc550 cc injectors
external wastegate running at 5lb spring
basemap chip tune
here's my problem. i was driving home from a friend's house one night and everything works fine, but when i got home and left again about 3 hours afterwards my blow off valve sounds funny now. before it would have the quick *psh* noise. now it has the noise but softer and a lot longer. so now it would sound quiet and *psssssssshhhhhhhh.......* i check all my couplings for leaks and vacuum lines; they all look fine. so i dont know whats seem to be the problem so here i am on honda tech. any inputs would be great. thanks.
jdm d16a sohc vtec
rc550 cc injectors
basemap chip tune
Re: (lv6l)
when you say universal bov, what style is it. Since you says pshhh noise and not a whistling sound, it is a mimic of the XS RFL? If so, you may need to put some oil or grease because it gets stuck.
Re: (LsCivic18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsCivic18 »</TD></TR><TR><TD CLASS="quote">It Shouldnt Move In And Out</TD></TR></TABLE>
my brand new garrett did.. not much only a few thous. Needs room for oil
Re: (HamiltonRex)
Why would you take a BOV sound change and assume the turbo is crapping out? As long as he's at the same psi as before when closing the throttle, it shouldn't vary the sound. My guess is that the diaphram/o-ring that seals the vacuum port is shot. If its leaking there, the bov will move very slowly.
i think i fix the problem. end up having a hairline crack on my vacumm hose and it effect my bov. iono why my gauge didn't change but i think it works now. so far so good. thanks a lot for all the inputs.
