flow rates for precision sc34
Old Dec 10, 2006 | 04:29 PM
hybridpatient95's Avatar
Default flow rates for precision sc34
would anyone happen to know the flow rates for a precision sc34 turbo?
also would this turbo be good to achieve 500whp? thanks guys
Old Dec 11, 2006 | 03:46 AM
rehehjqrejr
Old Dec 11, 2006 | 05:29 AM
Muckman's Avatar
Moderator in Chief
Default Re: (hybridpatient95)
the SC34 will flow about 54-55 lbs/min max'd out, which equates out to just under 800 cfm
Old Dec 11, 2006 | 09:23 AM
is that a good thing or bad? since you mentioned it would only flow that maxx'd out.
Old Dec 11, 2006 | 11:56 AM
Muckman's Avatar
Moderator in Chief
Its not good or bad, its the flow rates that you asked for.
Old Dec 11, 2006 | 02:04 PM
Importrev's Avatar
Default Re: (Muckman)
Good for about 550hp. Nice turbo....
Old Dec 11, 2006 | 02:09 PM
RyanEJ8's Avatar
As a very general rule of thumb you should be able to get approx 10hp for every 1 lbs/min flowed, but of course this is going to vary with each setup.
Old Dec 11, 2006 | 02:27 PM
Importrev's Avatar
Default Re: (RyanEJ8)
When I spoke to forcedinductions they said its 1lbs/min = 10.86hp.
Old Dec 11, 2006 | 04:34 PM
thanks guys. so i could make the amount of power i want.
this is going on a b16 with ramhorn manifold 3indp and exhaust
Old Dec 12, 2006 | 07:23 AM
RyanEJ8's Avatar
Default Re: (Importrev)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Importrev &raquo;</TD></TR><TR><TD CLASS="quote">When I spoke to forcedinductions they said its 1lbs/min = 10.86hp.
LOL, just round that off to 10hp because it's going to vary so much.
Old Dec 12, 2006 | 07:41 AM
tony1's Avatar
lol, or just round it to 10 because there is no correct answer. Whoever came up with 10.86hp per lb/min of airflow is full of ****...
Old Dec 12, 2006 | 09:08 AM
Importrev's Avatar
Default Re: (tony1)
If you base it off a turbo compressor map its about right on. Also that came from them since they test and manufactures parts for some of the big turbocharger companies....lol. I would imagine turbo companies don't hire idiots.
Old Dec 12, 2006 | 09:14 AM
tony1's Avatar
There's tons of misinformation out there, doesn't mean they're idiots, just ignorant sometimes.
The amount of power an engine will make with a given amount of airflow is completely dependant on the engine's efficiency.
Old Dec 13, 2006 | 06:58 AM
Importrev's Avatar
Default Re: (tony1)
Its an estimated #. I know and I'm sure they do that different VE's will produce different results, but its nice to have a rule of thumb #. Also since they test the units on test benches, I think they would have some insight.
Old Dec 13, 2006 | 07:19 AM
tony1's Avatar
10 is an estimated number. 10.86 is a number someone came up with because they didn't understand how it varies with engine efficiency.
You can't test this stuff on a test bench unless your test bench is an engine dyno. lol
Old Dec 13, 2006 | 07:29 AM
Muckman's Avatar
Moderator in Chief
Default Re: (tony1)
Taken from the Garrett tech website:
"What is my mass flow rate? As a very general rule, turbocharged gasoline engines will generate 9.5-10.5 horsepower (as measured at the flywheel) for each lb/min of airflow. So, an engine with a target peak horsepower of 400 Hp will require 36-44 lb/min of airflow to achieve that target. This is just a rough first approximation to help narrow the turbo selection options."
Old Dec 13, 2006 | 07:40 AM
Importrev's Avatar
Default Re: (tony1)
I'm sure the # is based on a median. Plus they have an engine dyno as well...lol.
Robert Singleto
Aug 31, 2011 03:05 PM
Blacklabel182
Suspension & Brakes
Jun 13, 2007 12:17 PM
foam
Northwest (Sales)
17
Apr 3, 2007 10:06 PM
Cidone
May 7, 2005 06:14 PM
mountaindewguy
Suspension & Brakes
Feb 24, 2005 02:17 PM
