need help boosting
Old Dec 15, 2006 | 07:19 PM
hatch96y7's Avatar
Default need help boosting
well i have come to the conclusion that i will not be getting my b18c soon so i got to go to another cheaper route
now my question is what turbo setups can i use to boost my y7
i might not go the mini me route so i need a setup that uses the y7 throotle body
what turbo setup can i use with out breaking my wallet and will still be able to push at leats 200whp
any info will be greatly appreciated
flamers feel free to bump my ****
Old Dec 15, 2006 | 07:50 PM
hatch96y7's Avatar
Default Re: need help boosting (hatch96y7)
bump
Old Dec 15, 2006 | 08:05 PM
boosted96coupe's Avatar
I used a homemade set-up. I got a t3 from the junkyard for $30, use the hf exhaust manifold get an intercooler and piping, then you just have to tune it. Ive been running 10 psi for a month and no problems.
Old Dec 15, 2006 | 08:07 PM
hatch96y7's Avatar
Default Re: need help boosting (boosted96coupe)
whats an hf manifold and u didnt get any injectors or anyother mods at all
Modified by hatch96y7 at 11:22 PM 12/15/2006
Old Dec 15, 2006 | 10:22 PM
hatch96y7's Avatar
bump
Old Dec 16, 2006 | 09:38 AM
HiProfile's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch96y7 &raquo;</TD></TR><TR><TD CLASS="quote">flamers feel free to bump my **** </TD></TR></TABLE>
Just read the FAQ. I highly doubt you'll have good luck piecing a HMT turbo setup together, let alone tuning it well. You'll probably have to get a prefabed kit, so figure in over $2k for that. Although if you're planning on getting the b18c in under 10k miles, you could get an ebay kit, run a basemap or even an fmu and arive at that b18c with a smoking car with boost, exhaust, and oil leaks all over.
Boost is only cheap if you've done it before, or know forced induction like you know the top side of your dick. Inexperienced people have had good luck before, but the vast majority of FI 'n00bs' destroy their first motor.
Old Dec 16, 2006 | 11:39 AM
hatch96y7's Avatar
Default Re: need help boosting (HiProfile)
thanks ur post helped me a lot
now if i went with the egay kit and just welded the weld better on my own at work will it still hold up good
also that is the reason that i am choosing to boost my cheap y7 because they are inexspensive and will most likely have one on hand for back up
and second i have access to diesel turbochargers and was wondering if i can put that on my civic will it work
since diesels redline at 3000rpm will that eliminate turbo lag
Old Dec 16, 2006 | 01:50 PM
hatch96y7's Avatar
bump for boost
Old Dec 16, 2006 | 03:22 PM
This was my second HMT setup, you dont need to waste 2k for a kit.
Honda HF exhaust manifold $30
Adapter plate $20
Intercooler $80
T3 Turbo $100
BOV $50
Chipped ECU with hondata $50
Inter cooler piping $40
DSM 450 injectoors $50
Making 12psi and having your motor last without waisting 2K PRICELESS
Old Dec 16, 2006 | 03:28 PM
Smoking car, exhaust and oil leaks all over????? Only if you dont know what your doing, and if thats the case you shouldnt be working on cars. My first tubo set-up worked awsome i was 17 and knew nothing about honda's i had the motor in the car for a year. The only reason i took it out was because it was a 1.5, i replaced it with a 1.6 v-tech and it ran great. Dont let anyone make you think you cant do it. If you have all the parts and take your time you will be fine with your first set-up.
Old Dec 16, 2006 | 03:31 PM
Yes a diesel turbo will work, my T3 is off a 1991 diesel mercedes, and it works great. You dont have to spend a fortune to make it work, alot of people just overkill and spend money on stuff they dont need. Just keep the boost under control and dont boost more then the motor can handle.
Old Dec 16, 2006 | 07:13 PM
92gisser's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted96coupe &raquo;</TD></TR><TR><TD CLASS="quote">alot of people just overkill and spend money on stuff they dont need. </TD></TR></TABLE>
a lot of people spend money on things they don't need?
or..
a lot of people spend money on things you think they don't need?
Old Dec 16, 2006 | 11:45 PM
hatch96y7's Avatar
Default Re: need help boosting (92gisser)
thanks the support guys i am still abit curious about the hf manifiold what is it where do i gt it from
Old Dec 17, 2006 | 05:22 AM
perseverance's Avatar
u can get a turbo exhaust manifold from ebay for like 100 bucks. u can get all ur intake piping from ebay for pretty cheap, ur intercooler will be cheap... ****... u can piece together a good kit from ebay. only things that make the big difference from egay and a good setup would be the manifold, the turbo, and intercooler. but if ur running mild boost i don't see any problems. and u can up ur injectors.. then you'd need to up your fuel pump. but for low boost it isn't even necessary.
Old Dec 17, 2006 | 05:41 AM
nsxmatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted96coupe &raquo;</TD></TR><TR><TD CLASS="quote">You dont have to spend a fortune to make it work, alot of people just overkill and spend money on stuff they dont need. </TD></TR></TABLE>
No, most people want a clean new setup that doesn't look like it was pieced from the trash bin.
Old Dec 17, 2006 | 06:27 AM
pheurton-skeurto's Avatar
but bottom line is that you can run a really reliable junkyard kit if you do your homework and tune the car well.
i run a hmt kit with the HF manifold, 13B turbo, some old *** intercooler, dsm 450's, dsm bov etc, etc...bottom line is that I USED HONDATA TO TUNE. i spent more on engine management than i did on the entire rest of my setup. it was tuned by corey at slowmotion here in columbus who is unbelievably reputable. you can have a fun, reliable, moderately fast setup for relatively cheap.
my advise to the OP is this: buy all of your turbo parts, do your homework and find ones that work with your engine and power goals and then budget about twice that amount on ems and tuning. youll be happy in the end. why buy the Titanic and ask a 4 year old to pilot it?
Old Dec 17, 2006 | 06:30 AM
Default Re: need help boosting (nsxmatt)
I have under $500 into my setup and it looks alot ****** better then some of the kits i have seen out there. If you do **** right it s not gonna look like its from a trash bin.
Old Dec 17, 2006 | 06:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pheurton-skeurto &raquo;</TD></TR><TR><TD CLASS="quote">but bottom line is that you can run a really reliable junkyard kit if you do your homework and tune the car well.
my advise to the OP is this: buy all of your turbo parts, do your homework and find ones that work with your engine and power goals and then budget about twice that amount on ems and tuning. youll be happy in the end. why buy the Titanic and ask a 4 year old to pilot it?</TD></TR></TABLE>
Im glad someone else thinks you can make a home made set-up look and work good!!
Old Dec 17, 2006 | 08:39 AM
hatch96y7's Avatar
im still wodering what an hf manifold is
is that the name of it
Old Dec 17, 2006 | 08:42 AM
hatch96y7's Avatar
and if i d buy turbo stuff from ebay is there any special names i should llook for as in the sellers and how reliable the stuff is
Old Dec 17, 2006 | 04:41 PM
Laserjock's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch96y7 &raquo;</TD></TR><TR><TD CLASS="quote">im still wodering what an hf manifold is
is that the name of it</TD></TR></TABLE>
go to this link to find more info on the HF manifold:
https://honda-tech.com/zerosearch
try asking here, they are more helpfull and friendly over there:
http://www.homemadeturbo.com/f...3;www
http://www.homemadeturbo.com/turbo_projects
coastertrav
Feb 5, 2008 09:16 PM
Youlose1305
Nov 26, 2006 09:24 AM
schardbody
Southeast (Sales)
Jun 15, 2006 04:24 AM
SpecialGoodness
May 4, 2005 08:10 PM
dubdeuce
Jul 9, 2003 02:49 PM
