damaged, but how much?
Old Dec 9, 2006 | 12:47 PM
em2ssm02's Avatar
Default damaged, but how much?
ok, i got a t3/t4 garrett turbo from a guy last weekend and later found out that he ended up selling it becuase his sleeve gave out, i wasnt too happy when i found that out.
anyways, the header and turbo were connected when i got it from him so when i got home i noticed there was some oil leaking out of the header, a lot more than i thought it should be, so i took them apart and turned the turbo so that the opening to the exhaust side was down and a bunch of oil poured out along with many little metal pellets, there were quite a bit of them too. i was growing a little more pissed off, so then i knew i had to take off the exhaust housing to see what was up inside of there. so i took it of and noticed this.
there were the three blades in that shot that actually had the metal torn and one or two others were just bent a little bit.
so i just wanted to know what i should do, the guy said we could work something out, this is my first turbo set up, i think i know a significant amount about them so dont flame me. i just dont know how much damage is too much.
also i noticed the metal "canister" type thing underneath the fan is able to lift up if you just pull up a little bit. this one in the pic thats circled, that seal is where it looks like oil is coming from.
i need to know what to do i have 3 options as of right now
1. keep it and just deal with it becuase its fine
2. get the money back and get one from blaast
3. get money to get it repaired
i kinda need to know what you guys think asap
thanks.
Old Dec 9, 2006 | 12:51 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: damaged, but how much? (em2ssm02)
the wheel is fucked, return it
the metal sleeve will move when the housing isnt on the turbo, but oil shouldnt be leaking regardless. seals are shot
Old Dec 9, 2006 | 12:56 PM
em2ssm02's Avatar
so you think i should get the money back? yeah i mean i just move that metal sleeve up a little bit and oil drips down the sides
Old Dec 9, 2006 | 12:57 PM
coneheadsracing's Avatar
Default Re: damaged, but how much? (wantboost)
Make him buy you a knew wheel, and pay to have the wheel assembaly rebalanced. Turbocity.com Cheap for rebalancing. My Garrett is not sealed on that side. The only seal you have is a c-clip to hold the shaft in. It uses air pressures to hold the oil in, usually when i take of my turbo i get oil leaking there too.
Old Dec 9, 2006 | 01:03 PM
em2ssm02's Avatar
where do you think i could get the same wheel from? its either a .63 or .60 a/r i'm not sure i know its one or the other.
Old Dec 9, 2006 | 01:14 PM
Default Re: (em2ssm02)
Theres people on here that could get you it, or like i said get a hold of http://www.turbocity.com and talk to them, send them pics and tell them what turbo, get a qoute and get some cash from the original seller. If you have any good local turbo shops, take it there. They will know what wheel you need.
Old Dec 9, 2006 | 01:16 PM
em2ssm02's Avatar
i just noticed you live in MI, i do too, i'm north of detroit about 20 miles. if your anywhere around there what turbo shops would you recommend
Old Dec 9, 2006 | 09:35 PM
I'm from the other side of the state, so not sure over there. I have one for sure over here, I can find the info if you would like. Theres another actual performance shop, not sure if they do rebuilds, i know they know how to. I've had the best pricing come from Turbo city though. You could also just send out your wheels, and they can get you a new exhaust wheel, and then balance the wheels for you, just have to mark and put back the same. That would be cheap as well. PM me if you want the shops info.
Old Dec 10, 2006 | 07:36 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (Mr Wonderfull)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Wonderfull &raquo;</TD></TR><TR><TD CLASS="quote">get your money back.. then kick him in the nutzzzzz...
youre welcome!!!! </TD></TR></TABLE>
basically the only way.
a standard rebuild is 250 without replacing wheels. so you are better off sending this *** his turbo back and buying a new one, it will be cheaper
Old Dec 10, 2006 | 09:48 AM
em2ssm02's Avatar
he's not an ***, he put the turbo on for under 50 miles and a sleeve gave out and he never checked the wheel. he said he'd do as much as he can to help out now, people make mistakes i just need to know what to do about it.
Old Dec 10, 2006 | 10:15 AM
CRXdan's Avatar
I woudl definetley get him to either give your money back in full or pay for the repair. He shoudl have assumed the turbo was damaged if the engine blew.
Old Dec 10, 2006 | 10:28 AM
Civicman86's Avatar
Default Re: (CRXdan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXdan &raquo;</TD></TR><TR><TD CLASS="quote">I woudl definetley get him to either give your money back in full or pay for the repair.</TD></TR></TABLE>
Yup thats what I would have done as well.
Old Dec 10, 2006 | 12:31 PM
morgan@synapse motorsport's Avatar
you're lucky at least the guy is honest amd willing to take responsibility for this.
Old Dec 10, 2006 | 02:23 PM
em2ssm02's Avatar
Default Re: (hybrdthry911)
yeah i just gotta sort all this out, he said hes gonna try to find a new wheel. ill probably give him til the end of hte week then ill just try to get refunded and get a new one or one from blaast.
Old Dec 10, 2006 | 06:30 PM
sell me the turbo for cheap
Aradin
Mar 8, 2015 06:50 PM
smoovy
Apr 19, 2009 11:09 AM
b16hybridsol
Jan 1, 2007 03:51 PM
fastcivicboy
Feb 9, 2006 09:22 PM
TURBOED-TEG
Jun 12, 2002 11:32 AM
