Boost lines?
Old Aug 5, 2010 | 04:15 PM
AaronGeisinger's Avatar
Default Boost lines?
I just boosted my integra... i need some info on the runnin the boost vacum lines i have a outlet on the side of the turbo and two outlets on the waste gate.... also if u have any helpful info on runnin the boost gauge,boost controler, and air fuel...
Old Aug 6, 2010 | 10:14 AM
dpetro1's Avatar
Default Re: Boost lines?
you would be better off on the forced induction forum.
1. side of turbo to lower port of wastegate
2. top port of wastegate is used only for electronic boost controllers. what controller are you using?
3. is your boost gauge mechanical or electric?
4. see #2, boost controller setup depends on type of controller being used
5. afr also depends on type of gauge being used (narrowband vs wideband)
so basically you need to give more specific info on the parts you are using
Old Aug 7, 2010 | 09:12 AM
lsd96teg's Avatar
forced induction faq will answer your questions, I used it two weeks ago to do the same thing
a1320addict
Aug 12, 2005 10:47 PM
MachAF
Jun 27, 2003 05:14 PM
sushibug
May 24, 2002 07:53 AM
simike
May 10, 2002 03:01 PM
Mucackus
Apr 26, 2002 08:45 AM
