tranny problem
Old Jul 27, 2010 | 10:55 AM
young geezer's Avatar
Default tranny problem
ok so i just put a new clutch in my gsr tranny and it was working just fine. but when the car is at running temp and driven for like 2 hours it would stop going in gears. only way it will go in gear is if i turn off the car and put it in gear and turn it back on. the clutch pedal feels stifer and wants to push back up. i changed the master cylinder before too. so what could be the problem. thanks.
Old Jul 27, 2010 | 09:38 PM
Default Re: tranny problem
no one ran into tkhis problem before?
Old Jul 28, 2010 | 04:11 AM
hbcrazy88's Avatar
well most of the time your trans is going to be harder to go into gear on lets say a cold day but once your car gets up to Op. temp the gears run smooth. this is usually because the oil hasnt got everywhere yet and is cold and not warmed up.... have you checky your tranny fluid? a new clutch should feel hard!
Old Jul 28, 2010 | 02:35 PM
Mindgamez's Avatar
Only way to really tell is to take the tranny back out and take a look. Maybee it was not aligned correctly. Did u put tranny Fluid in it when u were done?
Old Sep 16, 2010 | 12:14 PM
99hondacura's Avatar
From: down the street,bythe river in the van, co, united states
this happened on my ls/vtec swap an it turned out to be that the clutch wasnt torqued right. well as i did that my clutch fluid was leaking an caused this as well
after i fixed this everything worked out good
Old Sep 16, 2010 | 12:36 PM
tougetuned_ef's Avatar
when my crv did this it was cause my master and slave cylider both went. this is what the dealership said. good thing i got that warrenty when i bought it. it happened cause when you light up your wheels in a crv 1st gen it just eats up the cylinders. dont know why. kinda bugs me that i cant launch in the thing. oh its also a 5 speed.
allmotor2.1
Mar 3, 2008 06:02 PM
deez nuts
May 13, 2005 08:30 PM
tzonni
Dec 21, 2003 10:57 AM
HavokB18
Jul 26, 2003 05:32 PM
svtec
May 20, 2003 10:21 AM
