Good build?
Old Aug 6, 2010 | 04:51 PM
fivestarsi5's Avatar
Default Good build?
93 integra
b16 head port n polish
b18c1 block with itr pistions
itr headers
ctr tranny
i have the ecu to the b16 and the b18c, which one should i use for this setup?
Old Aug 6, 2010 | 08:59 PM
Default Re: Good build?
Also which cat should I run, stock itr cat? gsr cat? I live in CA so it needs to be smogged.
Old Aug 6, 2010 | 09:15 PM
90 integra da's Avatar
jdm type r pistons hopefully. usdm itr pistons will give you not very much compression cause of the low dome, about 10.8:1. which isnt bad i suppose but jdms would be better imo. solid everything else tho, should be a fun car
Old Aug 7, 2010 | 05:06 AM
Bored b18c1 block W/high compression ITR dome pistons, 11.5:1 I believe.
turbo_hatch93
May 21, 2006 11:02 PM
92integraVTECgsr
Mar 27, 2006 08:09 AM
JDMvtecDRAGSTA
Oct 19, 2004 09:21 PM
Shanksma
Jun 12, 2004 09:10 AM
Dodger2940
Aug 25, 2002 12:10 PM
