Price range
Old Aug 2, 2010 | 07:08 PM
smoked08's Avatar
Default Price range
ok well im going to get a new car and the only problem the guy said is that it needs new throw out bearing ..he told me he'd buy the part and put it on his self but id have to pay him alittle more but i wanna do research if it'd be cheaper to buy the part myself and take it somewhere for them to do it..so any advice? and its a 97 LS swapped to a GSR
Old Aug 2, 2010 | 07:43 PM
egsleepercivic's Avatar
Default Re: Price range
how much is he going to add on, also you might as well replace the clutch while your in there
Old Aug 2, 2010 | 08:06 PM
vtaker's Avatar
lol well.....how much is he asking for it?
Old Aug 2, 2010 | 08:09 PM
smoked08's Avatar
well he's selling it fixed and **** for about $3,500 and not fixed for about $3,200
and yeah thats very true i can do that but would it affect if i waited a bit till got a new clutch ? or have to get it right away i mean i would wait no longer then a 2months or less then that.
Old Aug 2, 2010 | 09:31 PM
vtaker's Avatar
Well it damn sure wont be cheaper than $300 to get that done. If it was me, I'd just find another car with no probs. The fact that the throw out bearing is broken probably means it was beat on or the clutch is old. Like eg said the clutch is probably going to need changing. You have to drop the trans anyways so might as well. So add $200 for a quality clutch which comes with the bearing. You also need gaskets, flywheel resurfacing, trans fluid, etc during the job ~$70. I don't know if he included that.
For a DIYer, the job shouldn't take longer than a weekend. And that's taking your time
Old Aug 2, 2010 | 10:32 PM
smoked08's Avatar
idk but ill ask him about it tho !! lol
Old Aug 3, 2010 | 01:17 AM
mouab18c1's Avatar
Buying a car that has problems will only lead you to DISASTER!
Old Aug 3, 2010 | 10:01 AM
dc2 teggy1120's Avatar
well the throwout bearing will be a bit expensive if ur also doing ur clutch which u should but i think hese giving it to u for a decent price
Old Aug 3, 2010 | 12:31 PM
smoked08's Avatar
yeah i think im jst gonna get it for $3,200 and buy the part myself and go to this badass shop were they do hella of a good job and have them put it in for me and while at it do the clutch also ..! and ill be set !
I got a clutch from this seller http://cgi.ebay.com/ebaymotors/EXEDY...Q5fAccessories
and it was a good exedy oem replacement kit used it for over 90k miles no problems
it lists both kits on the exedy site http://www.exedyusa.com/oe/Applications
just wanted to show you how much decent oem replacement parts actually cost
your looking at $130.00 in parts including shipping, the 300 he is charging is labor the parts aren't that that expensive
hope this helps
Old Aug 3, 2010 | 01:03 PM
racebum's Avatar
most used cars this age have problems of some sort. the cars that don't and have been maintained and repaired usually aren't for sale, or when they do sell fetch top dollar
a few notes about previously mentioned comments
1. there are no gaskets involved when you do a clutch job, there are seals you can replace if need be on the axles and rear main. the rear main you don't do without the correct tool.
2. the exedy oem from gripforce is a great clutch for stockish power levels. for the $100-150 they go for it's a great way to go, i also suggest this and not just doing the TB
3. get a labor quote from your shop before you make a choice. if you can buy this clutch and pay dude $200-300 to do all the work, that's not bad, the shop may want more
4. where did the gsr swap come from? how was it wired and what ecu is it on?
5. do a compression test on that engine when it's hot, unhook the distributor and do the test. numbers below 170psi when warm would worry me. every time i've seen a 140psi cylinder in a gsr it fractured an exhaust valve shortly there after due to excess oil consumption.
Old Aug 3, 2010 | 07:56 PM
smoked08's Avatar
yeah thanks alot guys this helps me alot !
Old Aug 3, 2010 | 11:50 PM
vtaker's Avatar
Those and the gaskets on the a-pipe.
VeeSykkz
Jan 7, 2016 02:29 PM
Failsafe88
Sep 14, 2010 07:37 PM
stanglover37
Jul 30, 2007 09:13 PM
skabone
Sep 21, 2003 07:40 AM
badcabala
Dec 7, 2001 06:43 PM
