Bogging Down DA
Old Aug 2, 2010 | 07:43 PM
djw19842005's Avatar
Default Bogging Down DA
Evening Guys, I got a 91 Integra GS 1.8L that i have been trying to get on the road for about a month now.. I have been on here several times with questions and have gotten a little closer each time. The symptom I am having while driving is, I am having a misfire under acceleration (load) around 3K and 4K RPM. If im just cruising there seems to be no problem.
The timing is dead on, i have checked compression 155,150,155,155psi.. Replaced Distributor twice, new fuel pump, fuel filter, wires, and plugs.. yet she is still doggin out on me when i try to step the pedal to the metal.. Any Help would be greatly appreciated, really wanna get this car back on the road ASAP..
THANKS FOR THE IDEAS!!
Old Aug 2, 2010 | 10:15 PM
ls_vtec_da's Avatar
Default Re: Bogging Down DA
i just had the same problem with my DA. I got a ls-vtec in a 1992 gsr and first, my misfire started when i would vtec it, then it started to do it when i would just floor it on any rpms. so my dad told me to check the distributor cap, so i took it apart and it was corroded and then cleaned it and car runs really smooth and no more misfire.
Old Aug 2, 2010 | 11:41 PM
dizzy cap and rotor are brand new....
Old Aug 3, 2010 | 02:51 AM
Duane_in_Japan's Avatar
Gently clamp off the fuel return hose to the gas tank and see how it runs, just make one run and remove the clamp while still on the road, not when you come back to the house, just long enough to see if it helps, this is called Dead Head Pressure.
Old Aug 3, 2010 | 09:59 AM
dc2 teggy1120's Avatar
not enough ground? happened to my friands da and it worked after he added another ground cable
Old Aug 3, 2010 | 10:20 AM
I'm try checkin the grounds, and will try the dead head pressure see if either of these two things make a difference.. thanks for the ideas, i will let ya know what happens..
Old Aug 3, 2010 | 10:21 AM
cool keep it updated
Old Aug 3, 2010 | 02:50 PM
Tryed adding another ground and tried clamping the return line. neither made a difference.. uuurrrgggghhhh will i ever find this problem....
Old Aug 3, 2010 | 06:52 PM
Bump
Old Aug 3, 2010 | 09:16 PM
ls_vtec_da's Avatar
yeah now i drove the car about 100 miles and now doing the same thing again. now i am going to change the fuel pump and injectors and also see if all the grounds are good.
Old Aug 3, 2010 | 09:52 PM
think i am gonna take mine to the professionals.. i know my hondas pretty good, but this one has got me completely stumped!
Old Aug 4, 2010 | 02:57 PM
Car Was Dropped Off at Acura Dealership 2day.. hope i don't get to raped to find the problem...
Old Aug 4, 2010 | 07:34 PM
ls_vtec_da's Avatar
on mine its weird when i would clean the dizzy cap and rotor its fine i mean the vtec hits really hard. it keeps getting corroded.
Old Aug 6, 2010 | 04:59 AM
The first time you cleaned it was it white corrosion like aluminium corrosion or brown dust corrosion like steel rust. And then on later cleanings silver dust like fresh steel shavings.
Old Aug 6, 2010 | 05:59 AM
DazeMS's Avatar
interesting! i just replaced my cap from the one thats been on the car for awhile and mine had aluminum white powder like an arching issue and brown spots like steel corrosion. replaced my cap and didnt clear up my issue which is similar to the OP's topic.
Old Aug 6, 2010 | 09:25 PM
ls_vtec_da's Avatar
it was white like aluminum, also my dizzy has a little bit of oil on the bottom and sometimes my ignition doesn't even work and randomly get a check engine light.
Old Aug 10, 2010 | 07:51 AM
White is the aluminium tabs of the spark plug wire tabs corroding. The brownish rust is the main shaft bearing going bad.
There are rebuild kits available for the internal oil leak. But to know if its the cause of intermittent no spark, you would have to clean it completely out and start from there, get intermit spark and see how much oil has gotten into the dizzy at that time.
Anytime you have an oil leak on an engine, you need to change the PCV valve and hose to be sure there is not too much blowby being held back in the crankcase and being forced out of any weak seal that the pressure can find. Once that is out of the way, then you just start replacing leaking seals and gaskets.
Old Aug 10, 2010 | 12:03 PM
got the car finally fixed and running fine.. the problem was in the Distributor cap. the tiny lil spring that fits on the coil from the cap was broken causing the car to bogg down! running like a champion now~~!!!
Lude #1
11
Jan 9, 2011 01:05 PM
djw19842005
Aug 2, 2010 03:50 PM
gsilnc
Jun 21, 2010 09:48 PM
