Alternator Replacement? easy or hard to do?
Old Nov 23, 2002 | 12:42 PM
Shft@9GSR's Avatar
Default Alternator Replacement? easy or hard to do?
Well my alternator just died. I guess it was about due with 146K miles on it.
My question is... is this something that can be done without remove/disconnecting the drive axle? I know the book says to remove it.
If it is necessary to remove it, then I don't have the equipment and it will go to the shop.
I figure that I would ask here to see if it is possible to do without removing the driveaxle so that I can do the job myself. Any insight would be appreciated.
Also, does anyone know if the alternator is used on any other Honda's. Reason is that I have a honda dealership close but the Acura dealership is like an hour away.
Thanks for any information.
Old Nov 23, 2002 | 12:43 PM
comptechgsr2000
Guest
Posts: n/a
Default Re: Alternator Replacement? easy or hard to do? (Shft@9GSR)
You will have to remove the wheel axle to remove it. Have the shop do it.
Old Nov 23, 2002 | 12:59 PM
Shft@9GSR's Avatar
Default Re: Alternator Replacement? easy or hard to do? (comptechgsr2000)
Thanks for the response. It's greatly appreciated.
Old Nov 23, 2002 | 01:02 PM
94TealGSR's Avatar
ummm... i didnt hafta remove mine. WOuld've been easier if I did, but I didn't have to.
Old Nov 23, 2002 | 04:39 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Alternator Replacement? easy or hard to do? (94TealGSR)
you must have removed something, I'm pretty sure the alternator will not physically fit between the axle and firewall below, or between the firewall and intake manifold above. It's just too cramped. I removed the axle and center halfshaft, not too hard.
Old Nov 23, 2002 | 08:05 PM
mugenracer's Avatar
Default Re: Alternator Replacement? easy or hard to do? (PatrickGSR94)
No..it is not absolutely necessary to remove anything..it will come out with a little bit of jiggling about, i replaced mine a while back and managed to get it out (from the underside) without removing anything, i also managed to get the new one in, and bolt it up without removing anything, although it would have been a hella lot easier if the drive shaft were not in the way!
91akira
Aug 15, 2017 05:12 PM
david420
Aug 2, 2012 04:29 PM
tigueremalo
18
Jun 2, 2007 11:41 PM
Jap_Spec_Imports
Jun 27, 2006 10:30 AM
Synthead
Jul 31, 2005 08:55 PM
