CEL problem
Old Nov 26, 2002 | 01:41 PM
LsPower's Avatar
Default CEL problem
My o2 sensor had somehow gotten chopped and my cel was on. I finally replaced it and the cel was still on. It threw a code 41. Everywhere I read it is the o2 sensor heater or something like that. Does anyone know what tha hell this means?
Old Nov 26, 2002 | 01:54 PM
B00ST2nR's Avatar
Default Re: CEL problem (LsPower)
Reset your ECU and the CEL should go away. If it doesn't pop up again, don't worry about it. If it does, jump the code and see what it throws again. If its the same problem, then check it out. I wouldn't worry too much about it.
Old Dec 3, 2002 | 08:01 AM
zilverz's Avatar
.. try all those resets mentioned ... if still no resolution ... its the replacement O2 sensor.. or some wires are pulled from the connector btw what kind of o2 sensor do you have and where did you get it ..
Old Dec 3, 2002 | 08:56 AM
LsPower's Avatar
Default Re: CEL problem (zilverz)
It is an NGK o2 sensor from some place on the internet.
Boosted97Ej8
12
Oct 8, 2012 12:04 PM
DC2_Legend
Apr 16, 2009 08:25 PM
tmduck
16
May 27, 2007 08:21 PM
draxxus07
Sep 24, 2005 12:10 PM
