Long Term effect by HID
Old Nov 26, 2002 | 10:24 AM
SilverDc2's Avatar
Default Long Term effect by HID
im planning on getting HID and i was wondering if it messed up the projector or melts it because of its high voltage. since its not OEM HID/.
Old Nov 26, 2002 | 10:43 AM
Kelvin96GSR's Avatar
25 Year Member
Default Re: Long Term effect by HID (HondaTeg)
I beleive HID is lower voltage than normal bulbs. I don't know about how hot they are tho
Old Nov 26, 2002 | 12:26 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
The ballast steps up the voltage from 12V to a very high amount, but the bulb itself draws less current and runs cooler than halogen bulbs. That's one of the great things about HID, the current goes more into making light and less into making heat, so it's much more efficient.
Old Nov 26, 2002 | 12:28 PM
Duckz's Avatar
Default Re: Long Term effect by HID (PatrickGSR94)
what about projecting an HID beam through a lens designed for reg. bulbs?
Old Nov 26, 2002 | 12:31 PM
10K2HVN's Avatar
Default Re: Long Term effect by HID (Kelvin96GSR)
Higher output of light and a little bit more heat, but not enough to damage headlights. users LESS power - ~35 watts...
Old Nov 26, 2002 | 12:37 PM
10K2HVN's Avatar
Default Re: Long Term effect by HID (duckz)
if you get a well made one it should be the same beam pattern as halogen because they place the capsule in the same place as the filament...
Old Nov 26, 2002 | 12:38 PM
pervytheclown's Avatar
Default Re: Long Term effect by HID (10K2HVN)
I thought that real HIDs put out way less heat than normal bulbs do, and less voltage too. I know that they are bright as hell.
Old Nov 26, 2002 | 12:58 PM
Community Builder
The arc in an HID capsule used to generate the light does not create nearly as much heat as a halogen bulb, because halogen bulbs are incandescent and operate by the principle of running current through a wire will heat it up enough so that it glows, which makes the light (and LOTS of heat). Your headlights should run cooler with an HID capsule inside them.
Old Nov 26, 2002 | 01:47 PM
JASON77's Avatar
Default Re: Long Term effect by HID (pervytheclown)
I think you are confusing voltage with current draw and wattage .....the HID systems I've seen use the ballast (step up transformer) to multiply the voltage and to create the spike in voltage to establish the arch. I am not sure what voltage level it operates at, but I would think it would be similar to a florescent lighting ballast.
voltage x current = watts
Old Nov 26, 2002 | 04:03 PM
Community Builder
Default Re: Long Term effect by HID (FREAKA)
or, watts drawn by the accessory divided by volts = amps (current used).
Old Nov 26, 2002 | 04:39 PM
Jay J's Avatar
Prince of Zamunda
From what I know it runs cooler than regular halogens
Old Nov 26, 2002 | 04:40 PM
Jay J's Avatar
Prince of Zamunda
Get HID's it'll make your night time driving exp. easier and also in the fog too
Old Nov 26, 2002 | 05:35 PM
SilverDc2's Avatar
Default Re: Long Term effect by HID (neuspeed)
which one is good for a integrai think the 6000k sounds good. i like the with the purple beam like the BMWs. whats better phillips or hella
Old Nov 26, 2002 | 05:43 PM
Cramerox's Avatar
i can already see where this is going...
Old Nov 26, 2002 | 06:32 PM
jdmotorsports's Avatar
Default Re: Long Term effect by HID (Cramerox)
arnt the ballast like 30k volts or so? there actualy cook to the touch unlike normal bulbs. no long term damage, and the only effect would be wanting hid's on all your cars.
Old Nov 26, 2002 | 07:43 PM
EndlessGarageEG6's Avatar
Beautifully said....
Old Nov 26, 2002 | 09:26 PM
uNF$@#!'s Avatar
Default Re: Long Term effect by HID (CRintegreX)
when in doubt, do the tongue test ....once on the bulb, and once on the ballast when on
Old Nov 26, 2002 | 10:06 PM
acura_typer's Avatar
Banned
I have read on several HID retrofit websites that you should install a harness that has a relay in it to power the ballasts. Sure, they don't draw a bunch of power while on, but for the first few seconds of power up, they draw considerable more power than standard headlamps and will deteriorate the stock wiring.
maal15
Dec 13, 2008 11:30 AM
ssm-gd3
Lighting
Sep 28, 2008 10:12 AM
viskii420
Lighting
25
Oct 31, 2007 04:21 PM
dc4drewH
Jul 12, 2004 09:38 PM
Loveless
Jun 16, 2003 01:58 AM
