Headlight help...ASAP!!
Hey This is kind of an emergency. I'm an hour away from my house and I went to my car to turn it on and when I turned my lights on, they turned on then turned off for some reason. My high beams work, and all my tail lights and in dash lights are working but my regular low-beams won't turn on. Is this a fuse problem? And if so which one should I check. Thanks..I need to get home tonight
I'm not anywhere near my car right now so sorry if I'm wrong.. but aren't the headlights on different fuses? (or maybe that was the case on another car I was working on/a friends car)...
check the fuses, check the bulbs, check the wiring.. could also be the switch...
nyrican23
May 22, 2009 06:41 PM
DropSquadCivic
Sep 11, 2003 10:00 PM
FnkyChnkyMnky
Jun 20, 2002 02:21 PM
