Quick Question
Old Nov 26, 2002 | 11:23 AM
2SLO's Avatar
Default Quick Question
I have a 97 LS with a 97 B20b block. im getting CEL number 54 which is:
54
96-98 Civic
97-98 CRV
94+ Integra CKF Sensor (Crankshaft Speed Fluctuation) defective circuit or unplugged / defective sensor
now i noticed on the LS block there was a plug connector by the crank pulley that wasnt on the b20 block. is this a big deal and is anyone else having this problem? im using the LS wiring harness and LS ecu... someone please help me out.
Old Nov 26, 2002 | 11:50 AM
2SLO's Avatar
Default Re: Quick Question (2SLO)
ttt
Old Nov 26, 2002 | 07:32 PM
sic2kSi's Avatar
Was your car running well before you found this?
Old Nov 26, 2002 | 08:37 PM
IntegrasGoFast's Avatar
your getting that because your LS ecu thinks there should be a sensor there. as for your engine i don't know if it will cause problems, it probably will. I would suggest getting an ecu that is compatible with the b20 or even if you could find a piggyback that can lie to the LS and make it think everything is ok, that would work.
Topdawgg
Mar 27, 2007 10:24 AM
nvmyb20hatch
Nov 20, 2004 04:18 PM
nvmyb20hatch
Nov 20, 2004 02:01 PM
trashkilla
Oct 18, 2004 08:24 AM
not so civic
Feb 23, 2002 10:04 AM
