Brake Problem?
Old Nov 22, 2002 | 02:30 PM
92 GS-R's Avatar
Default Brake Problem?
My rear brake pads are touching my rotor on my car while the ebrake is off. Is this normal? if not, how big of a gap should there be
Old Nov 24, 2002 | 05:55 PM
92 GS-R's Avatar
Default Re: Brake Problem? (92 GS-R)
anyone?
Old Nov 24, 2002 | 09:10 PM
Chewie's Avatar
your rear rotors might be warped
Old Nov 25, 2002 | 11:18 AM
92 GS-R's Avatar
Default Re: Brake Problem? (Chewie)
I just got new rotors so i don't think thats the problem
thanks for the reply though
Old Nov 25, 2002 | 01:00 PM
GSRaCeRbOI's Avatar
what do you mean "touching" is it actually grabbing and the brakes are giving resistance to the car/wheels? or do you just mean that the clearance between the pads/rotors/caliper are very near the rotor/appear to be very close/touching the pads?
its not like a mountain bike/bike where when you release the brake lever the brake pads spread a lot apart from the rim.... if thats what your thinking it should be.. not sure if I'm understanding your question correctly.. is it actually grabbing/applying the brake when the e-brake is off?
put your car in gear, put wheel chocks on the front tires.. jack your car up and support it on jack stands.. and release the e-brake.. now spin the rear tires by hand and see if they spin freely w/ the E-brake down.. if they spin freely your OK.. there isn't much visual clearance between the pads and rotor..
[Modified by GSRaCeRbOI, 5:12 PM 11/25/2002]
Old Nov 25, 2002 | 03:27 PM
92 GS-R's Avatar
Default Re: Brake Problem? (GSRaCeRbOI)
thanks for the info i will have to try this out.
The pads just looked like they were touching. Im not sure if they are grabbing or not. thanks for the detailed response
KyleVA
Nov 24, 2009 09:39 AM
cyco
Honda Motorcycles
Jun 2, 2009 08:11 AM
CRexcellence
Jun 5, 2007 12:49 PM
dip-set
Jul 15, 2003 02:45 PM
976
Jun 6, 2002 06:12 PM
