Compression test results...
Old Nov 25, 2002 | 09:12 AM
illi Adik's Avatar
Default Compression test results...
I recently posted last week about some engine issues, loss of power, rough idle, and quite frankly my car sounds like a subaru
My compression test this past friday resulted in 180 all across until cyl. 4 it only pulled 60.
My question is what do you think is the cause of this? My thoughts are possible or a few bent valves. Input is very much appreciated. Thank you
Oh my car has the JRSC w/ 8lb pulley, i/h/e, ignition, portflow headwork..etc just to sum it up a little bit.
[Modified by Jackson4Door, 1:12 PM 11/25/2002]
Old Nov 25, 2002 | 01:42 PM
illi Adik's Avatar
Default Re: Compression test results... (Jackson4Door)
anybody?
Old Nov 25, 2002 | 01:46 PM
MySlowTeg's Avatar
hmm..notice any oil burning?
Old Nov 25, 2002 | 02:45 PM
IN VTEC's Avatar
Your guess is as good as mine. A leakdown test will either tell you more or nothing at all.
Altho, I'd put my money down on the valves and maybe the rings included. I don't think you could lose that much compression through the rings and still be running. You probably would have had to of dropped a ring land to lose that much.
Old Nov 25, 2002 | 02:53 PM
get wet racing's Avatar
Default Re: Compression test results... (IN VTEC)
Yo dude I would say most likely your piston rings, my b16 ran 215 psi
Old Nov 25, 2002 | 02:56 PM
Austin's Avatar
Default Re: Compression test results... (get wet racing)
Do a leakdown test, it will help you to find where your problem is.
Austin
Old Nov 25, 2002 | 03:01 PM
DR3AM's Avatar
Yeah, a leak-down test should help to explain the problem.
My guess would be that you're getting blow-by due to bad piston rings..
Old Nov 25, 2002 | 03:45 PM
Austin's Avatar
Default Re: Compression test results... (Gizzzer98)
Either that or he had a ring land go...
Old Nov 25, 2002 | 04:40 PM
illi Adik's Avatar
Default Re: Compression test results... (Austin)
Yea, thanks a lot fellas, I set up an appointment for tomorrow so we will see what that tells, wherever I am losing the pressure from. Thanks a lot for the input.
and yes it is using more oil then usual, i think its all related to my car running rich, at least as far as the rings go.
Old Nov 25, 2002 | 04:58 PM
97hb's Avatar
Redo the compression test and squirt some oil down in the cyl that is low. If it raises back up then your rings are f-ed up.
Old Nov 25, 2002 | 05:27 PM
FormulaGSR's Avatar
Default Re: Compression test results... (97hb)
This is a backwoods method, but it works a lot. With you rcar idling hold a dollar bill up to the tail pipe. If it trys to suck it up you got bent exhaust valves. Also have you overreved your motot I.E. downshifted too high resently, that is the best way to bend valves.
Old Nov 25, 2002 | 06:13 PM
andrewM's Avatar
Default Re: Compression test results... (FormulaGSR)
if the car has been feeling underpowered, making noise, or giving strange vibrations it could be bad. but it could be as simple as u started to drain the battery by time u reached the 4th cylinder. did u do the test again starting with the 4th cylinder? and making sure u turn it over enough to get a good result. if u do put oil in the cylider only put a little bit in or ull have smoke comin out the exhaust for a while.
good luck dude
Old Nov 25, 2002 | 09:13 PM
illi Adik's Avatar
Default Re: Compression test results... (andrewM)
Yea, I am hoping it is just bent valves, easily replaced compared to a lot of other things.
Old Nov 26, 2002 | 12:53 AM
benny5177's Avatar
About 4 months ago i wasted my ring lands on the #4 cylinder of my 95 Integra GSR. It has exactly the same symptoms your car is showing. 180 psi all the way across untill the #4 cylinder which showed about 60 psi. However, my motor would also send smoke out the breather indicating an obvious leak (piston related). I'm willin to bet your ring land is cracked...
It's time to pull the motor and rebuild it I've just been through that nightmare
Old Nov 26, 2002 | 08:36 AM
illi Adik's Avatar
Default Re: Compression test results... (benny5177)
Ouch, Im keeping my fingers crossed that its not going to be that. But I mean hey at least you have a fresh motor
Old Nov 26, 2002 | 03:59 PM
IN VTEC's Avatar
Almost the same story with mine. Compression on #4 dropped from 220 to 80, and only one of the valves got tapped. I do mean tap....no marrings on the valve or piston that indicated damage.
Old Nov 26, 2002 | 04:35 PM
SIK IN DA HED's Avatar
New User
40? DAYM... thats bad. might be your rings.
Vladglad
20
Dec 18, 2013 02:56 PM
humboldt_skim
May 31, 2008 08:18 AM
John.
Jun 12, 2006 08:45 AM
Sport_Injected
Aug 25, 2004 09:21 PM
Propulsion
Jun 5, 2002 11:48 PM
