Check engine light help needed ASAP!!!
Old Jun 5, 2003 | 01:47 PM
420aNT's Avatar
Default Check engine light help needed ASAP!!!
My damn car will not rev past 2000rpm. I checked the ecu for codes and I am not sure if I am reading them correctly. I think it is either a code 5-10-or 15. I think I am getting a code 15 though. What can this be. My car is running hondata S100 w/boost and 780cc injectors. The car is buring gas like mad and blowing black smoke like crazy. Someone help me out ASAP. I already tried a new map sensor but it made no difference. The car is an 2001 GSR with a fully built motor.
Old Jun 5, 2003 | 03:06 PM
zad5's Avatar
Default Re: Check engine light help needed ASAP!!! (18gTeg)
0 ECU
1 Oxygen Content
3 Map Sensor
4 Crank Angle Sensor
5 Map Sensor
6 Coolent Temperature
7 Throttle Angle
8 TDC Position
9 No 1 Cylinder Position
10 Intake Air Temperature
63 Intake Air Temperature
12 Exhaust Gas Recirculation System
13 Atmosphere Pressure
14 Electronic Air Control
15 Ignition Output Signal
16 Fuel Injector
17 Vehicle Speed Sensor
20 Electronic Load Detector
21 VTEC Solenoid Valve (1.8L GSR)
22 VTEC Oil Pressure Switch (1.8L GSR)
23 Knock Sensor
30 TCM Signal A
31 TCM Signal B
41 O-2 Sensor Heater
43 Fuel Supply System
45 System Too Rich or Too Lean
48 Primary Heated O-2 Sensor
54 Crankshaft Speed Fluctuation Sensor
61 Primary O-2 Sensor Circuit
63 Secondary O-2 Sensor Circuit
67 Catalyst System
70 Automatic Transaxle
71-74 Random Misfire
80 Exhaust Gas Recirculation
86 Engine Coolant Temperature Circuit
90 Evaporative Emission Control System Leak Detected
91 Fuel Tank Pressure Circuit
92 Evaporative Emission Control System Insufficient
long flash means 10 and if it does 5 short flashes after then its 15. i think thats how it works if i remeber correctly.
Old Jun 5, 2003 | 03:20 PM
420aNT's Avatar
okay so I found out that I had the plugs for the IAC and the IAT sensors switched. I switched them over correctly but now I am getting a code 14 and my car idles high as crap. It will not rev up either it just cuts out and stumbles.
Old Jun 5, 2003 | 04:55 PM
boosted_dc2's Avatar
780's!!!!!! that seems a bit large....my car can barely idle with 440's
Old Jun 5, 2003 | 09:23 PM
2k1_ITR_0736's Avatar
Default Re: Check engine light help needed ASAP!!! (hooked_up_gsr)
btw, if hondata in car, and doesnt run past 3000 rpm, somethign is FUCKED up. mine did that once. i needed a new eeprom. not good, but good luck, let us know whats up
98tegLSvtec
Jul 31, 2011 01:33 PM
lblingldawg
Apr 27, 2006 03:10 PM
Del Sol on Steroids
Dec 1, 2005 07:56 PM
2dark2bslow
Jun 2, 2004 06:33 PM
LSVTEC408
Dec 10, 2002 04:22 PM
