guide for installing cams.
Old Jun 5, 2003 | 03:57 AM
216.226.142.95:27016's Avatar
Default guide for installing cams.
how does one know when installing cams that the the right lobes are facing the right direction? the intake cam has a notch on the distributor side but what about the exhaust cam? i have a vague idea with having the engine at TDC and just using that as guidance to make sure the cams are put on correctly but can someone elaborate or explain how to do it correctly?
one last thing, is a timing gun necessary for cam installation, to check timing, since the timing belt is slipped off?
Old Jun 5, 2003 | 04:04 AM
tilt's Avatar
Default Re: guide for installing cams. (216.226.142.95:27016)
when you put on the cam gears it will let you know where tdc is.
no. just use some whiteout or paint.... Set the crank to tdc then make marks on the belt to reference from when you put it back on. I made two marks on the tbelt teeth before and after the outside dots on each gear. When I put the new gears on i just made sure the two white marks on the belt on each side went between the dots. This takes out any guesswork of any kind.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 216.226.142.95:27016 &raquo;</TD></TR><TR><TD CLASS="quote">how does one know when installing cams that the the right lobes are facing the right direction? the intake cam has a notch on the distributor side but what about the exhaust cam? i have a vague idea with having the engine at TDC and just using that as guidance to make sure the cams are put on correctly but can someone elaborate or explain how to do it correctly?
one last thing, is a timing gun necessary for cam installation, to check timing, since the timing belt is slipped off?</TD></TR></TABLE>
Old Jun 5, 2003 | 11:18 AM
Default Re: guide for installing cams. (tilt)
nice ill give that a try. since the cam gears have a key in it that corresponds to the cams, can i just use this as reference to make sure its on right? like cams inserted in interlocked with the key and install it with the arrow pointing up?
Aqueous5
Mar 5, 2008 09:15 AM
SrT4u2nV
May 23, 2006 03:55 AM
I got a honda
Oct 25, 2005 04:33 PM
ITRfaithful
Oct 28, 2003 09:58 PM
quis23
Oct 8, 2002 04:02 PM
