Remote start install help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nOOber »</TD></TR><TR><TD CLASS="quote">hope some of this helps...
+12 Volts White Ignition Harness +
Ignition Black/yellow Ignition harness +
Accessory Yellow Ignition harness +
Accessory 2 White/black Ignition harness +
Starter Black/white Ignition harness +
Tachometer Green at coil AC
Lock Black/white alarm harness -
Unlock Orange alarm harness -
Parking Brake Green/red At switch -
Doorpin Black/white or green/red alarm harness -
Brakeswitch Green/brown At brake pedal switch +
Parking Lights Red/black at fusebox +
Clutch bypass is going to be negative at the switch.
what are the accessory ignition things for? Do I need them hooked up? Also about the Brakeswitch, I hook that up to the brake light right? Will it still work if I do not hook it up (Brakeswitch)?
How do I bypass the clutch to work without being pressed?
im_the_teacher
Audio / Security / Video
Jun 4, 2003 05:10 AM
