will a CEL code 41 disable vtec?
Old Jun 4, 2003 | 08:07 AM
E-spec Tuner's Avatar
Default will a CEL code 41 disable vtec?
my vtec is disabled for some reason, im throwing a 41 code with is primarty o2, i've heard that will disable vtech. is this true?
Old Jun 4, 2003 | 09:20 AM
JimBlake's Avatar
Default Re: will a CEL code 41 disable vtec? (PCdc2)
I don't think so. Code 41 is the preheater, it's not the actual O2 measurement.
Old Jun 4, 2003 | 10:05 AM
Default Re: will a CEL code 41 disable vtec? (JimBlake)
would an 02 measurement disable it? because i have a testpipe and i believe my secondary is also throwing a code
Old Jun 4, 2003 | 10:07 AM
Frito1's Avatar
it is the failure of the o2 sensor, sensor 1, which is on the forward part of the cat. had the same problem and it was because i pulled the wires out, pluged them in and everythinhg is okay now.
Old Jun 4, 2003 | 10:22 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PCdc2 &raquo;</TD></TR><TR><TD CLASS="quote">would an 02 measurement disable it? because i have a testpipe and i believe my secondary is also throwing a code</TD></TR></TABLE>
What code? There's codes for the O2 measurements and there's different codes for the preheaters.
The primary is there so the ECU can adjust A/F ratio. The secondary is there so the ECU knows whether the cat is working. (Well, that's a little simplified.) Each one has a preheater because otherwise they wouldn't work for the first couple minutes after you start the engine.
I'm not really sure about disabling VTEC, I just suspect that the PREHEATER errors won't disable it. I don't know about the real measurement errors...
YaBoiTHiZZ
12
Mar 28, 2012 08:10 PM
DarkBB4
Aug 27, 2005 09:31 AM
MysteryWagon
Mar 10, 2005 08:07 PM
rammstein
Dec 18, 2004 01:17 PM
