did compression test, seem high???
Old Jun 3, 2003 | 07:46 PM
JunIntegra's Avatar
Default did compression test, seem high???
my numbers on my 96 gsr with 58000 miles came to: 221-220-221-223. is that high on a stock internal gsr?? ive seen people with like 170's numbers on theres. i was really happy with the numbers personaly. what you think?
Old Jun 3, 2003 | 07:54 PM
B U N M A N G O's Avatar
Default Re: did compression test, seem high??? (JunIntegra)
that's perfectly fine... mine were in the 150's and 170's... my piston rings are fucked
Old Jun 3, 2003 | 07:59 PM
seanb18c1's Avatar
Your compression guage might be off, can you do another test with someone else's gauge?
Mine was 230,230,225,230
Old Jun 3, 2003 | 09:07 PM
neo1z's Avatar
Default Re: (seanb18c1)
Those are great numbers -- congrats
Old Jun 3, 2003 | 09:19 PM
beaterman's Avatar
does not matter just as long as the numbers are about the same thats the most important thing.
Old Jun 6, 2003 | 06:17 PM
af97civic's Avatar
i didi a comp test, and it was 60 across the board
Old Jun 6, 2003 | 07:05 PM
BlkGSR's Avatar
Default Re: did compression test, seem high??? (af97civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by af97civic &raquo;</TD></TR><TR><TD CLASS="quote">i didi a comp test, and it was 60 across the board
Were you pressing the gas pedal down during the test?
Old Jun 6, 2003 | 08:27 PM
CNSK's Avatar
Default Re: did compression test, seem high??? (BlkGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlkGSR &raquo;</TD></TR><TR><TD CLASS="quote">
Were you pressing the gas pedal down during the test?</TD></TR></TABLE>
really...are you pressing the gas and clutch down???60 across, you aint going no where...running like a dx if not worst
Old Jun 6, 2003 | 08:51 PM
Bill Hook's Avatar
Default Re: did compression test, seem high??? (DrMartin)
I'm wondering if my numbers are too low: 212-212-212-210
B18C1 w/ 35K miles.
Old Jun 6, 2003 | 11:04 PM
SSBP DC2's Avatar
Default Re: did compression test, seem high??? (Bill Hook)
for accurate results, you must perform the test with wide open throttle at normal operating temperature
Old Jun 7, 2003 | 06:29 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bill Hook &raquo;</TD></TR><TR><TD CLASS="quote">I'm wondering if my numbers are too low: 212-212-212-210
B18C1 w/ 35K miles.</TD></TR></TABLE>
Nope your numbers are fine.
Rule of thumb:
When your numbers are not consisent, then there may be a problem, or if the numbers are way off there's a problem.
GSR's should be 200+ althe way across.
Old Jun 7, 2003 | 06:30 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JunIntegra &raquo;</TD></TR><TR><TD CLASS="quote">my numbers on my 96 gsr with 58000 miles came to: 221-220-221-223. is that high on a stock internal gsr?? ive seen people with like 170's numbers on theres. i was really happy with the numbers personaly. what you think?</TD></TR></TABLE>
No your's are great. don;t complain about them being high, just low.
Old Jun 12, 2003 | 08:54 PM
d0nkeyxPunch's Avatar
Banned
Default Re: did compression test, seem high??? (HybridcivicLS-T)
how about on a '00 JDM ITR motor? Mine was 210 straight across.
Old Jun 12, 2003 | 09:52 PM
MachAF's Avatar
Default Re: did compression test, seem high??? (EM1b18cR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1b18cR &raquo;</TD></TR><TR><TD CLASS="quote">how about on a '00 JDM ITR motor? Mine was 210 straight across.</TD></TR></TABLE>
thats fine. agian as long as their within 20psi of each other. All testers vary.
Old Jun 17, 2003 | 04:38 PM
Andrew 825SM's Avatar
Default Re: did compression test, seem high??? (MachAF)
mine is 180-175-175-175 with a 3mm headgasket. When I put oil in it shoots up to 210 across.
Old Jun 17, 2003 | 04:39 PM
E-Rok's Avatar
EPIC TUNING
Default Re: did compression test, seem high??? (Andrew 825SM)
gotta love those carbon deposits.
Old Jun 19, 2003 | 12:53 AM
BlkGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrew 825SM &raquo;</TD></TR><TR><TD CLASS="quote">mine is 180-175-175-175 with a 3mm headgasket. When I put oil in it shoots up to 210 across.</TD></TR></TABLE>
oil???
Old Jun 25, 2003 | 05:13 PM
B_1_8_hatch's Avatar
why do you put oil in the cyl?
Old Jun 25, 2003 | 05:25 PM
Chubz's Avatar
your motor is shot
on a 97 JDM ITR motor no **** 270 psi all day long. I couldnt believe it. I had a gsr motor with a b16 head with JUn IIIs and ctr pistons i would hit way past 300 psi in every cylinders. I even broke two testers
Old Jun 25, 2003 | 05:28 PM
Chubz's Avatar
B18C1 w/ 35K miles.</TD></TR></TABLE> Those numbers are fine
Old Jun 25, 2003 | 05:34 PM
Rayman's Avatar
If you put oil in and your compression raises....means your piston rings are losing compression.
Old Jun 26, 2003 | 01:57 AM
BlkGSR's Avatar
Default Re: (Rayman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rayman &raquo;</TD></TR><TR><TD CLASS="quote">If you put oil in and your compression raises....means your piston rings are losing compression.</TD></TR></TABLE>
Can anyone verify this information?
Old Jun 26, 2003 | 12:33 PM
Chubz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rayman &raquo;</TD></TR><TR><TD CLASS="quote">If you put oil in and your compression raises....means your piston rings are losing compression.</TD></TR></TABLE> anytime you add oil to your sylinder is raises compression. that does not mean your losing compression
Old Jun 26, 2003 | 05:16 PM
96_GSR's Avatar
Oil just creates a better seal.
Old Jun 27, 2003 | 12:39 AM
HybridGSR1's Avatar
Default Re: (96_GSR)
my LS motor is 150~170 across.. is that about rite? wuts normal for LS?
