Compression Test Numbers....
Old Jun 7, 2003 | 01:55 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Compression Test Numbers....
I just got finished doing a compression test on my 96 LS, and results were appox ~ 150 across all four cylinders.
Are these decent numbers? They seemed a bit low to me, but Im not sure.
TIA,
-Will
Old Jun 22, 2003 | 12:20 AM
B_1_8_hatch's Avatar
Default Re: Compression Test Numbers.... (integra707)
anyone know for this guy?
Old Jun 22, 2003 | 09:46 AM
seanb18c1's Avatar
ever try doing a search?
Old Jun 22, 2003 | 09:57 AM
98coupe's Avatar
From: NOVA, but OC MD for the summers, 10th St., Tyson R.I.P, USA
On my 94 LS I got 180 cross all four give or take 2-3 psi. Your rings might be lighting alittle go by but all are even so that is good. If you pour a little motor oil in each cylinder they should all jump up a lot.
Old Jun 22, 2003 | 10:48 AM
len's Avatar
len
If they're all even through out, you might want to check valve clearance.
If you are burning oil constantly then you have bad rings.
But whatever is happening it's nothing but normal wear and tear.
Also, different test equipment and method would yield different results.
Old Jun 22, 2003 | 11:41 AM
boostedsol's Avatar
Default Re: Compression Test Numbers.... (len)
i have 2000 ls and the numbers were 150 across also. Thants right for a LS.
Old Jun 22, 2003 | 10:19 PM
Default Re: Compression Test Numbers.... (boostedsol)
what should the numbers be for an ls motor...does anybody know?
Old Jun 23, 2003 | 10:43 AM
es four's Avatar
Default Re: Compression Test Numbers.... (93hb)
This is an old thread.....
I forgot to hold down the gas while doing the compression test, thus yeilding slightly lower numbers.....
I did a search and found my answer.
thanks anyway though.
-Will
Old Jun 23, 2003 | 11:23 AM
shadowdawn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedsol &raquo;</TD></TR><TR><TD CLASS="quote">i have 2000 ls and the numbers were 150 across also. Thants right for a LS. </TD></TR></TABLE>
I have a 99 and got 185-190 across the board...... its all relative, compression numbers dont' tell you much of anything unless 1 or more are WAY off from the rest.
Do a leakdown and find where your leaking if you care. My compression numbers were fine, but after a leakdown I found I was leaking 4-9% thru the exhaust valves on #2 and #3 cylindars...... nothing major, but not happy either.
armintheman
Oct 4, 2010 09:57 PM
Creator
Apr 26, 2007 09:55 AM
arejaygsx
Dec 19, 2006 06:32 PM
DualCamEK
Feb 22, 2006 10:52 AM
Jamison
Feb 11, 2002 08:51 PM
