code 65, need help
Old Jun 4, 2003 | 07:30 AM
bgod's Avatar
Default code 65, need help
a friend just triggered code 65 on the way to work. i don't have a manual in front of me. anyone know what code 65 is?
any help is appreciated.
Old Jun 4, 2003 | 06:42 PM
tub_sephiroth's Avatar
Default Re: code 65, need help (bgod)
Secondary Heated Oxygen Sensor Heater. Open or short in Secondary 02 Heater circuit.
Old Jun 4, 2003 | 06:45 PM
TSIntegra's Avatar
he is going to start to have low voltage problems tell him to go under the dash and check his fuses, check the vehical speed sensore fuse it might be popped
Old Jun 4, 2003 | 09:35 PM
Default Re: code 65, need help (TSIntegra)
How is his O2 sensor going to cause low voltage?
Old Jun 5, 2003 | 09:50 AM
TSIntegra's Avatar
Default Re: code 65, need help (tub_sephiroth)
that secondary o2 sensor is all linked into the altenator and the battery, i had the same problem 2 weeks ago and a guy at honda said that i should check my fuse under the dash and i should check it and the fuse was popped. if the speedo works then dont worry about it
Keevin77
Oct 28, 2011 06:18 PM
jrami020
Oct 18, 2009 02:24 PM
twiztid_989
34
Apr 24, 2009 12:01 PM
Cashbrun
Oct 1, 2005 09:47 PM
CivicEK.PDX
Feb 20, 2004 07:54 PM
