Starter Problems?
Old Dec 29, 2003 | 09:50 AM
jdmhamster's Avatar
Default Starter Problems?
has anyone had any starter problems on their tegs? if so.. what were the "symptoms" and how old was your car when it happened...?
Old Dec 29, 2003 | 11:12 AM
jdmhamster's Avatar
Default Re: Starter Problems? (jdmhamster)
anybunnny?
Old Dec 29, 2003 | 03:53 PM
grlstockb18c1's Avatar
i have a 95 teg gsr with 170k on it. about 2 months ago my starter went bad. At first i thought it was my car alarm, b/c it broke so i stopped using it. ive heard that if you havent used the alarm for a certain amount of time, the car senses it and can lock you out your car or not let you start your car. Honestly, there were no signs at all. I woke up one morning on my way to work and it just never turned over. lights would just come on and that was that...
Old Dec 29, 2003 | 04:31 PM
AlphaKennyWun's Avatar
symptoms:
1. Sometimes it cranks, sometimes it doesnt.
2. Your battery is good but car still wont crank over.
2. When it doesnt crank you sit and wait 5-10 sometimes 30 minutes and then it cranks.
cure:
Take it out yourself (two bolts one wire) and go to a starter rebuild place.
Mines going 2 years strong after a rebuild and cost me $60, took 1 hr to fix.
I think a new one was over $200 when i was searching.
Old Dec 29, 2003 | 04:37 PM
jdmhamster's Avatar
Default Re: Starter Problems? (S03Burner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S03Burner &raquo;</TD></TR><TR><TD CLASS="quote">symptoms:
cure:
I think a new one was over $200 when i was searching.</TD></TR></TABLE>
thanx for the info.. i thought i was going to have no one reply back.
do u know what part the fixed? my friend told me i might just need to replace the rotor n cap.. ?
ohh and where did u go to get it rebuilt?
Old Dec 29, 2003 | 05:05 PM
I took it to a place in so. fla called crank and charge where they rebuild alternators and starters. Just look in the yellow pages thats how i found one.
The guy said that water is what causes starters to go bad. I dont know exactly what he replaced but I think your friend was right or maybe the guy said the contacts inside...not sure.
Old Dec 29, 2003 | 05:06 PM
jdmhamster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S03Burner &raquo;</TD></TR><TR><TD CLASS="quote">I took it to a place in so. fla called crank and charge where they rebuild alternators and starters. Just look in the yellow pages thats how i found one.
The guy said that water is what causes starters to go bad. I dont know exactly what he replaced but I think your friend was right.</TD></TR></TABLE>
thanks!!!!
Mars401
Nov 14, 2016 02:16 PM
RUBZERK
Sep 16, 2004 01:38 PM
TABIAS
Apr 10, 2004 04:09 PM
Bklyn TSi
Audio / Security / Video
Sep 27, 2001 07:33 PM
