CTR piston question...
Old Dec 30, 2003 | 05:56 AM
94B18B1Teg's Avatar
Default CTR piston question...
Do you know how big they are in oversize? If I bored the LS block to 2.0L (84MM) will CTR pistons in oversize fit?
Old Dec 30, 2003 | 06:03 AM
IN VTEC's Avatar
Default Re: CTR piston question... (94B18B1Teg)
No. Not even close.
Old Dec 30, 2003 | 06:24 AM
b19coupe's Avatar
Oversize CTR pistons are 81.25mm.
Modified by b19coupe at 5:02 AM 1/5/2004
Old Dec 30, 2003 | 09:05 AM
. o 69 o .'s Avatar
Default Re: CTR piston question... (b19coupe)
try endyne, http://theoldone.com/components/pistons/ the will have what you need
Old Dec 30, 2003 | 01:13 PM
riceball777's Avatar
stock bore is 81mm
over sized ctr pistons need a 81.5mm bore
the .040 over sized needs a 82mm bore
Old Jan 5, 2004 | 01:10 AM
2fknlo's Avatar
Default Re: CTR piston question... (riceball777)
Do CTR pistons come oversize with 82mm bore?
Old Jan 5, 2004 | 04:13 AM
b19coupe's Avatar
Default Re: CTR piston question... (2fknlo)
Oversize CTR pistons are 81.25mm and need an 81.25mm bore. 82mm is too big.
Honda OEM pistons are not 0.040" over.
I don't know if you can see it, but on the 0.25 over ITR pistons there is an .25 inked onto the dome, just to the right of the "P73".
RC_SKUBY
Northwest (Sales)
Jul 9, 2006 10:04 AM
Eaglekper0046
Aug 3, 2005 07:18 PM
