Struct bars
Old Dec 29, 2003 | 10:48 AM
JFG Kevin's Avatar
Default Struct bars
hey...i have a 2000 teg....i wanna get a brace bar's...which two bars match this requirment...i seen it done b 4...just don't know which bars
Old Dec 29, 2003 | 11:11 AM
vain's Avatar
Default Re: Struct bars (aznstyler119)
i'm guessing you're asking about strut bars... there's tons of them out there. are you going to autocross? or are you getting it for the bling factor?
Old Dec 29, 2003 | 12:09 PM
JFG Kevin's Avatar
Default Re: Struct bars (vain)
well...i'm gettin it for a lil of both......but mainly fo the upgrade for my suspension...i wanna make my car feel tight on the corner....i meant to say a double struct bar match...i wanted to know which two struct bars are able to use together at the same time
Old Dec 29, 2003 | 12:18 PM
96 Ls lnTeG's Avatar
Carbing, Benen, Skunk2, Edelbrock all good brands even oem type-r ones all
Old Dec 29, 2003 | 12:23 PM
JFG Kevin's Avatar
Default Re: Struct bars (96 Ls lnTeG)
i know some brands...but do you know which two struct bars can be use together...at the same time.....i dont' want a 3 point stuct tho...
Old Dec 29, 2003 | 12:39 PM
I found this pic it is on Ek.. though you can possibly so the same thing on a teg Its a Cusco MT an an spoon bar... hope this helps
Old Dec 29, 2003 | 05:42 PM
JFG Kevin's Avatar
the problem with my teg...is i broke off the stub for the screw where the stock stuct goes...so i need somethin that connects like the neuspeed and the one that connect to ur shocks knocks...
Old Dec 29, 2003 | 06:57 PM
beaterman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznstyler119 &raquo;</TD></TR><TR><TD CLASS="quote">the problem with my teg...is i broke off the stub for the screw where the stock stuct goes...so i need somethin that connects like the neuspeed and the one that connect to ur shocks knocks...</TD></TR></TABLE>
ok first off you have said stuct like eight times in this post and its strut bar.
now for the question. best bet would be the nuespeed bar and then just a ebay or similar one. you are going to want something high and low.
Old Dec 29, 2003 | 06:59 PM
conesmasher's Avatar
Default Re: Struct bars (beaterman)
APC makes a really fancy bar
ZEAL-SPORTS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 Ls lnTeG &raquo;</TD></TR><TR><TD CLASS="quote">I found this pic it is on Ek.. though you can possibly so the same thing on a teg Its a Cusco MT an an spoon bar... hope this helps
That is sick, my friend Bryan did that when he had his old Integra. ;}
Old Jan 1, 2004 | 06:27 PM
Outkasted24's Avatar
Two bars? Don't you think that's overkill?
Just get the Neuspeed 4 point bar, Thats what I have installed, It's not that expensive and does the job by bolting to the 4 most extended points of your strut towers.
But if your really stuck on that 2 bar thing...I know that The Neuspeed 4 point and the stock GS-R bars will work together.
Good luck with your decision
-Jeff
Old Jan 1, 2004 | 06:40 PM
Default Re: (Outkasted24)
2 Bars Is prolly more for Looks I run a Carbing 3pt & Gsr
GsDAteg
May 23, 2006 02:57 AM
haitian1
12
Feb 16, 2006 04:35 PM
WH0R3nEF9
Mar 14, 2005 08:31 PM
Paratrooper
Mar 1, 2004 10:31 AM
InfamousRS
Jan 29, 2002 08:00 AM
