stereo install
Old Dec 30, 2003 | 06:29 PM
pinoyboy204's Avatar
Default stereo install
how do i install an aftermarket cd player onto my integra? its a 90 integra ls 4 door sedan. i couldn't take it out since it was a little more complicated ( i owned a EF before). any help would be greatly appreciated. thanks
Old Dec 30, 2003 | 10:25 PM
integrx's Avatar
New User
Default Re: stereo install (pinoyboy204)
do you have the harness? if not you should get that first, i think you have to remove some bolts in the back on the radio(bolted to the panel), and you also have to take some other screws out. Look at team-integra.net
Old Dec 31, 2003 | 03:23 AM
BlackThorN's Avatar
honestly...if you can't even take it out poking around and looking for screws do you think you should be messing with it in the first place
installing a headunit is pretty much the easiest thing to do ever
either ask crutchfield or someplace for install instructions, find a friend that has done it on ANY car (trust me its' just a matter of time before you figure out what to unscrew)
or pay someone to do it for you
Old Dec 31, 2003 | 08:33 AM
RedTegLS's Avatar
Default Re: (BlackThorN)
I have to disagree a little. I worked around stereo's for years and I can install an amp and subs with my eyes closed but i could never do the decks very good. Unless you have the wiring harness and then its color to color and any bonehead can do that.
Old Jan 9, 2004 | 07:23 AM
Default Re: (RedTegLS)
got the deck installed, i was just an idiot and found out that there was 2 screws on the back that i had to take off on the factory deck.
my new question is,
how do i secure the deck? i couldn't use the OEM ones because my aftermarket doesn't have the holes to mount the brackets to connect to the frame...
Old Jan 9, 2004 | 07:40 AM
BlackThorN's Avatar
ahhh!
now you've reached the problem lots of people have
some people use zip ties, personally I tucked the harness behind the wires under the shelf the headunit sits on
mine can still come out but it's in there pretty good
good luck
Old Jan 9, 2004 | 11:08 AM
xxxmikenicexxx's Avatar
You also need a dash kit, which comes with plastic mounting hardware and can be found at walmart or most audio shops.
Calavera
Audio / Security / Video
18
Aug 13, 2003 10:32 AM
camera obscura
Jun 11, 2003 04:44 PM
TypeR1558
Dec 18, 2002 08:25 AM
maxxdout
Oct 26, 2001 06:01 PM
