what are the diff between 98-01 p72?
Old Dec 30, 2003 | 01:34 PM
integra-modder's Avatar
Default what are the diff between 98-01 p72?
The ems is different for 00-01, so im guessing there were changes to the stock unit too...
What are they?
Old Dec 30, 2003 | 02:35 PM
sa21199's Avatar
Default Re: what are the diff between 98-01 p72? (integra-modder)
are you talking about the ecu? Cuz a lot of things on the gsr is stamped p72
Old Dec 30, 2003 | 03:00 PM
IN VTEC's Avatar
Addition of the immobilizer function.
Old Jan 3, 2004 | 05:37 PM
Default Re: what are the diff between 98-01 p72? (IN VTEC)
Yes, I was refering to the ECU...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Addition of the immobilizer function.</TD></TR></TABLE>
If I buy someone elses ECU does this mean my car theoretically wont start with their ECU?
Old Jan 5, 2004 | 02:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra-modder &raquo;</TD></TR><TR><TD CLASS="quote">If I buy someone elses ECU does this mean my car theoretically wont start with their ECU?</TD></TR></TABLE>
can anyone verify this?
Old Jan 5, 2004 | 04:34 PM
youngvedder's Avatar
i have an '01 GSr and put in a OBD I P08 ECU and had no problems....I switch back and forth sometimes, and no probs....
YV
Old Jan 6, 2004 | 06:10 AM
Default Re: what are the diff between 98-01 p72? (youngvedder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youngvedder &raquo;</TD></TR><TR><TD CLASS="quote">i have an '01 GSr and put in a OBD I P08 ECU and had no problems....I switch back and forth sometimes, and no probs....
YV</TD></TR></TABLE>
the harness matches up?
Old Jan 6, 2004 | 09:31 AM
i2un's Avatar
Are you asking about OBD 2a and OBD 2b differences? And how to identify which is which?
Click the link:
http://hondata.com/techecuid.html
Modified by i2un at 8:32 PM 1/6/2004
Old Jan 6, 2004 | 09:36 AM
BlackSage's Avatar
I believe there is a OBDII-OBDI harness. So it can be done.
Old Jan 6, 2004 | 09:54 AM
i2un's Avatar
Default Re: what are the diff between 98-01 p72? (BlackSage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackSage &raquo;</TD></TR><TR><TD CLASS="quote">I believe there is a OBDII-OBDI harness. So it can be done.</TD></TR></TABLE>
Correct. But it is technically OBD2a - OBD1 harness. And OBD2b - OBD1 harness.
Old Jan 6, 2004 | 02:12 PM
Default Re: what are the diff between 98-01 p72? (i2un)
What is the ECU in an 01 GSR? is it a P72 ODB IIa?
Old Jan 6, 2004 | 05:15 PM
I used a harness, and didnt have any problems with the emobilizer....worked great.
YV
Old Jan 6, 2004 | 05:18 PM
i2un's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra-modder &raquo;</TD></TR><TR><TD CLASS="quote">What is the ECU in an 01 GSR? is it a P72 ODB IIa?</TD></TR></TABLE>
It should be a P72 OBD IIb. But you should check the connectors to make sure. If you click the link I posted above....you can see the differences in ECU's from the picture. Oldest on the bottom- Newest on top.
I have a 98 Gsr and that used a P72 OBD2a Ecu. In certain late model 98 GSR's on up they used P72 OBD2b Ecu's.
Old Jan 6, 2004 | 05:24 PM
i2un's Avatar
Your 01 Ecu should use the left 3 plugs and have a open space at the end. My OBD2a Ecu has a space in the center.
Old Jan 7, 2004 | 07:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i2un &raquo;</TD></TR><TR><TD CLASS="quote">Your 01 Ecu should use the left 3 plugs and have a open space at the end. My OBD2a Ecu has a space in the center. </TD></TR></TABLE>
Correct, however my ecu doesnt have that rubber thing on the left side as the hondata page shows.
Old Jan 7, 2004 | 09:52 AM
i2un's Avatar
Correct, however my ecu doesnt have that rubber thing on the left side as the hondata page shows.</TD></TR></TABLE>
The rubber thing on the side isn't anything. Your just looking for the pins for the connector plugs of the harness.
Old Jan 7, 2004 | 07:07 PM
do you know if there is anyway to retain the same key code on the immobilizer when switching ecu's?
Greg50Lt
Honda Civic (2006 - 2015)
Nov 17, 2007 06:44 PM
LILSOWEK
Mar 25, 2007 07:53 PM
CeeJayy
Jan 29, 2007 08:03 PM
memorybox
Nov 28, 2006 07:58 PM
93civciv
Apr 7, 2005 07:40 AM
