alarm question
Old Dec 29, 2003 | 02:30 PM
gsr-2nr's Avatar
Default alarm question
i posted this in gen discussion but since its for my teg i thouhgt id c if i could get more info this way and tried searchingl already this is a dumb question but i dont know much **** about electronics. i am looking to get a upgraded ecu prob a chipped obd 1 p72. my questions are how are alrams wired to your ecu mine is wired to my ecu is it just spliced into some wires or is it more complicated than that. also going to the obd 1 ecu from obd 2 will there be problems with the new programming and stuff and cause the alarm to not function properly. any input will be beneficial to me. thanks
_______
Old Dec 29, 2003 | 03:47 PM
gsr-2nr's Avatar
Default Re: alarm question (gsr-2nr)
anybody?
Old Dec 29, 2003 | 04:13 PM
undaunted209's Avatar
what kind of alarm do u have? i install alarms and have never hooked up an alarm to any ecu wires.. u shouldn't have any problems at all..
basic alarms is tapped into ur: parking lights, starter, ignition, door lock/unlock, dome light wires..
if u have remote start then probably the tach and brake. so you shouldnt have any plsm. goodluck.
Old Dec 29, 2003 | 09:27 PM
gsr-2nr's Avatar
when i looked at my ecu i c wires going to it and its the alarm wires
Old Dec 29, 2003 | 09:32 PM
P1mpSlap's Avatar
Interesting. The way you could find out is get the installers manual for your alarm and match the wire colors to whatever is going into the ecu.
Old Dec 29, 2003 | 11:25 PM
i've installed a few cliffords.. and have one myself.. never have i had to tap one into the ecu... the install menu is available on http://www.clifford.com if not then try http://www.directed.com goodluck
mr_munro
Audio / Security / Video
Feb 16, 2012 11:23 PM
climb_on
Aug 2, 2007 12:25 PM
tominos
Jan 20, 2004 10:25 PM
90CRX
Nov 4, 2003 04:50 PM
DRxCIVIC
Sep 21, 2002 09:26 AM
