5 BOLT CONVERSION FOR LS
Old Apr 25, 2004 | 06:57 PM
Sil_RS's Avatar
Default 5 BOLT CONVERSION FOR LS
WHAT PARTS ARE REQUIRED FOR A 5-114 CONVERSION ON A LS?
I KNOW IT NEEDS NEW CALIPERS & BRACKETS, PADS & ROTORS,
HUB ASSEMBLIES FRONT & BACK. IS THERE ANY ELSE, I NEED TO KNOW?
lIKE DOES THE CV SHAFT SPLINE OF THE LS, FIT THE TYPE-R HUB OR
WHEEL BEARING?
I NEED CONFIRMATION BEFORE I START THE CONVERSION.
Old Apr 25, 2004 | 07:17 PM
Danger's Avatar
Default Re: 5 BOLT CONVERSION FOR LS (Sil_RS)
are you buying everything sperate ?
Old Apr 25, 2004 | 08:57 PM
2tacosfor99cents's Avatar
he doesnt know....
Old Apr 25, 2004 | 08:59 PM
Kendall's Avatar
Why not just buy a complete conversion from someone like http://www.passwordjdm.com?
Old Apr 26, 2004 | 01:05 AM
JDM KING's Avatar
i believe the jdm spline is 36mm and the usdm is 32 check that out first!
Old Apr 26, 2004 | 05:02 AM
94ls's Avatar
spend your $$ elsewhere man
Old Apr 26, 2004 | 06:24 AM
IntegraBoy04's Avatar
Default Re: 5 BOLT CONVERSION FOR LS (94ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94ls &raquo;</TD></TR><TR><TD CLASS="quote">spend your $$ elsewhere man</TD></TR></TABLE>
It's his money, let him do what he wants with it.
Old Apr 26, 2004 | 06:39 AM
Im better than you's Avatar
like what bitch boy? a body kit? some altezza lights and some neon underglow lights?
Old Apr 26, 2004 | 06:47 AM
Default Re: 5 BOLT CONVERSION FOR LS (Im better than you)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Im better than you &raquo;</TD></TR><TR><TD CLASS="quote">
like what bitch boy? a body kit? some altezza lights and some neon underglow lights?</TD></TR></TABLE>
Shut up, ******* noob. You really shoudn't come on this board, and right away be a smart ***.
Old Apr 26, 2004 | 06:51 AM
Dc2 Powered's Avatar
haha what a dumb noob i think that better then you noob posted somthing yesterday and they ripped him a new one now hes trying to do it to someone eles.. noob no wounder nobody likes the 2003/2004 ppl :-( i'm 2003 hahah
yea spend ur money elesware.. turbo! jdm front end ! aztezza! lol jp **** school i have 3 min to get there cya
Old Apr 26, 2004 | 06:55 AM
phuq yoo's Avatar
Default Re: 5 BOLT CONVERSION FOR LS (IntegraBoy04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraBoy04 &raquo;</TD></TR><TR><TD CLASS="quote">
Shut up, ******* noob. You really shoudn't come on this board, and right away be a smart ***.</TD></TR></TABLE>
doesnt sound like you have much to say either about it ***
Old Apr 26, 2004 | 08:15 AM
tegmech's Avatar
Please explain the difference in reasoning between a 5 LUG conversion and altezzas etc. The reason for you doing the conversion is just so you can be a stunna. The reason why your not wanting to talk about altezza's and neons is that you probably already have them.
Old Apr 27, 2004 | 06:54 PM
Sil_RS's Avatar
Default Re: 5 BOLT CONVERSION FOR LS (Allmotordc2integ)
WHAT IF I USE THE HUBS FOR THE US TYPE-R
DO YO THINK IT WILL FIT ON THE BEARING OF A LS AND
THE SPLINE OF THE LS?
Old Apr 27, 2004 | 06:59 PM
svtec's Avatar
L D E S
spend like 30 bucks on a new keyboard that comes without the caps lock key.
Old Apr 27, 2004 | 07:00 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sil_RS &raquo;</TD></TR><TR><TD CLASS="quote">WHAT IF I USE THE HUBS FOR THE US TYPE-R
You're making this much more complicated than it really is. The spline issue only regards JDM ITR's and only requires different axles. The stock LS axles will work fine with USDM hubs. I still think your best bet will be to purchase a complete conversion as a kit. It will end up being much cheaper, and you won't have to shop for all the parts.
And please cut your caps lock off.
jmoney45
Dec 6, 2007 06:16 AM
rdssk8rcs1
Jun 13, 2007 08:14 AM
eglslsd
May 20, 2007 07:43 PM
bluteggy00
Jan 29, 2007 03:33 PM
Project X
May 11, 2003 12:56 PM
