PISTON RINGS - THE GAP?
Old Apr 25, 2004 | 08:56 PM
Anthrax-VX's Avatar
Default PISTON RINGS - THE GAP?
my setup is going to be custom rods with type R pistons - maybe even just some LS rods.. but ne ways. i need to know what the gap has to be for the piston ring gap - someone lemme know with some knowledgable info..
also wondering do they come from the factory with the right gap - if not.. y not?
im assuming if htey dont they always come larger so u can make the piston ring gap smaller, correcT? and what methods do u use in order to make the gap larger - do u just use like a stone grinder or use some dikes or wut?
thx alot fo ur help guys.. really appreciate it.
Old Apr 26, 2004 | 05:48 PM
deepgreengsr's Avatar
Default Re: PISTON RINGS - THE GAP? (Anthrax-VX)
to make the gap larger in seattle i call 425 644 8898 and order new rings. to make them smaller you must grind and check, grind and check. use a ring grinder or a small file if no one is avaliable.
civic-8442-
May 13, 2010 12:24 PM
95blackEG
May 23, 2007 02:50 PM
DC2TT
Jan 9, 2006 07:47 PM
Pengo
May 22, 2004 12:05 PM
ghettocrxsi
Nov 18, 2003 10:25 PM
