Reverse gear problem
Old Apr 22, 2004 | 10:14 AM
iMaGin's Avatar
Default Reverse gear problem
ok, now when I shift to reverse, it feels harder to get it in gear than before, does anyone have any idea what is the problem? maybe the clutch fluid?
Old Apr 22, 2004 | 10:46 AM
mini-v-si's Avatar
Default Re: Reverse gear problem (iMaGin)
I'm also having the same problem as you...still don't know, wait to see if anyone know.
Old Apr 22, 2004 | 11:32 AM
xplanetearth420x's Avatar
Default Re: Reverse gear problem (94tegGSR)
maybe a sychro
Old Apr 22, 2004 | 11:36 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Reverse gear problem (xplanetearth420x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xplanetearth420x &raquo;</TD></TR><TR><TD CLASS="quote">maybe a sychro
Don't quote me on this, but I didn't think the reverse gear had a synchros. How is getting into first gear? If that's slightly difficult as well, it could be your linkage being slightly off since 1st and Reverse are the two extremes on the shift lever.
Do something simple like a fluid top-off and see how that goes.
Old Apr 22, 2004 | 12:43 PM
mini-v-si's Avatar
Default Re: Reverse gear problem (shamoo)
sorry to jack this thread but yeah it is kind of hard to shift to first also, not smooth, recently did a swap too.
Old Apr 22, 2004 | 12:46 PM
kreamy's Avatar
ya linkage should be your main suspect....mine wont go into reverse sometimes...so you gotta put it in neutral to realine everything and put it back, it should go right in...as for other gears...try double declutching if you have any blown synchros.
Old Apr 22, 2004 | 12:53 PM
mini-v-si's Avatar
Default Re: (kreamy)
it just recently happen, that it had a hard time going to first and reverse.
NOOdS
Apr 20, 2009 11:04 AM
Mmmeecho
10
Jul 28, 2008 09:06 PM
boosted_EM1
12
Feb 7, 2008 12:58 PM
DC5_lov3r
Dec 10, 2007 05:51 PM
exquisite
Sep 9, 2003 05:30 PM
