headlight adjustment
Old Apr 22, 2004 | 09:23 PM
TSAngry's Avatar
Default headlight adjustment
im trying to adjust my headlights because my car is lowered and i want to aim them up a bit. i know how to adjust them and i overadjusted them. they aim real high now. i hear your suppose to park roughly 25 feet away from a wall, but how high should the cutoff be against the wall? i tried 4 feet but after that the headlights aimed way too high. any suggestions.
Old Apr 22, 2004 | 09:46 PM
Padawan's Avatar
Darth ModerVader
Default Re: headlight adjustment (O1Dc2)
First, measure the distance from the ground to the center of your headlights. Then, draw a line against the wall using that measurement as the height. When parked 25 feet away, your cutoff should be approximately 4 inches below the line that you drew. This is a good starting point, but I always use trial and error when aiming headlights. It took me a few days and a few trips to the "dark wall" to get my girlfriend's Cabrio E-codes aimed to my liking.
Old Apr 23, 2004 | 07:21 AM
TSAngry's Avatar
Default Re: headlight adjustment (Padawan)
when u say cutoff, do u mean the top of the line that the light makes off the wall?
Old Apr 23, 2004 | 07:44 AM
Padawan's Avatar
Darth ModerVader
Yes. In actuality, there should be two "hot spots" that show up (brighter circles), and I believe the center of these hot spots should be 4 inches down from the line, but the cutoff will be close enough. As I said, you should also do some trial and error once they're roughly adjusted. A dark road will show you if they need to be moved up or down an inch. Basically, you just never want the lights to be aimed higher than that center line that you drew.
Old Apr 24, 2004 | 12:41 PM
TSAngry's Avatar
got ya. thanks.
Old Jul 19, 2004 | 09:07 PM
ILuvJDMITR's Avatar
i seem to be having problems adjusting the high and low beams seperately... each adjuster seems to adjust both
Old Sep 19, 2004 | 03:12 AM
xAznRac3rx02's Avatar
Default Re: headlight adjustment (ILuvJDMITR)
this should help.... http://www.autooptiks.com/aiming.html
em2~b!tch
Honda Civic (2001 - 2005)
Jan 20, 2010 12:32 AM
mr. robot-o
Aug 22, 2008 12:17 PM
erikiksaz1
Feb 24, 2007 06:33 AM
vandeec5
Mar 3, 2004 10:35 AM
JforJonathan
Feb 11, 2004 07:01 PM
