tickin in engine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n2oteg »</TD></TR><TR><TD CLASS="quote">how do I adjust the valves or do I need to take it too a shop? how bad is that on the engine and what causes it?</TD></TR></TABLE>
You need a valve cover gasket from autozone, maybe some gasket sealer, and feeler guages. There are already step-by-step tutorials on H-T, so just do some simple searches. I found these in a quick search:
https://honda-tech.com/zerothread?id=837444
This link might help if a valve adjustment doesn't fix it.
http://student.ucr.edu/~ohe02/
There's a DIY for a B18B
Either way, keep searching. It's not that hard, but if you really want to take it to the shop, they might charge you a lot. Good luck...
From the type of question your asking us i'd say your not exactly up to par with honda motors, thereby eliminating the option of doing it yourself. I say screw it! take it in to a shop and have it professionally done.
A valve adjustment is not as easy as one might think.
ViCtOr VaHn
Apr 4, 2007 03:58 PM
